Leetcode - Design Hit Counter(1)
My code:
public class HitCounter {
TreeMap<Integer, Integer> tree;
private int counter = 0;
/** Initialize your data structure here. */
public HitCounter() {
tree = new TreeMap<Integer, Integer>();
tree.put(0, 0);
/** Record a hit.
@param timestamp - The current timestamp (in seconds granularity). */
public void hit(int timestamp) {
counter++;
tree.put(timestamp, counter);
/** Return the number of hits in the past 5 minutes.
public int getHits(int timestamp) {
int end = tree.floorKey(timestamp);
int begin = timestamp - 300;
if (begin <= 0) {
return tree.get(end);
else {
begin = tree.floorKey(begin);
return tree.get(end) - tree.get(begin);
* Your HitCounter object will be instantiated and called as such:
* HitCounter obj = new HitCounter();
* obj.hit(timestamp);
* int param_2 = obj.getHits(timestamp);
自己用 TreeMap 写了出来。
然后研究了下TreeMap
他的 put, get, remove, containsKey, floor 都是 log(n) 时间复杂度。
所以这种实现方法, hit, getHits 的时间复杂度都是 O(log n) |
