NSEnumerator.h
NSEnumerator.h
/*  NSEnumerator.h
    Copyright (c) 1995-2015, Apple Inc. All rights reserved.
#import <Foundation/NSObject.h>
@class NSArray<ObjectType>;
NS_ASSUME_NONNULL_BEGIN
* The fast enumeration protocol NSFastEnumeration is adopted and
* implemented by objects wishing to make use of a fast and safe
* enumeration style.  The language "foreach" construct then can
* be used with such objects.
* The abstract class NSEnumerator itself is taught how to do this
* for convenience by using -nextObject to return items one at a time.
typedef struct {
    unsigned long state;
    id __unsafe_unretained __nullable * __nullable itemsPtr;
    unsigned long * __nullable mutationsPtr;
    unsigned long extra[5];
} NSFastEnumerationState;
@protocol NSFastEnumeration
- (NSUInteger)countByEnumeratingWithStateNSFastEnumerationState *)state objectsid __unsafe_unretained [])buffer countNSUInteger)len;
@end
@interface NSEnumerator<ObjectType> : NSObject <NSFastEnumeration>
- (nullable ObjectType)nextObject;
@end
@interface NSEnumerator<ObjectType> (NSExtendedEnumerator)
@property (readonly, copy) NSArray<ObjectType> *allObjects;
@end
