一.类似的,学OC封装下网络请求的工具
详细的见本人的另一篇文章Swift3.0系列之基于Alamofire4.0网络层封装
二.新建一个swift文件,将所有的API请求写在该文件下
import UIKit
let saleAPI = "xxxxxxxxxxx?channel=ios-b1&device=iPhone&includeActivity=true&includeSpecial=true&scale=2&version=5.4.21"
class ZLMSaleAPI: NSObject {
class func requestSaleData(_ finished escaping (_ result:AnyObject? ,_ error:NSError?)->()){
NetworkTools.shareInstance.requestData(methodType: .GET, urlStr: saleAPI, parameters: nil){
(result,error)in
finished(result,error)
三.这里建model不多说(我只取自己要的字段),两个model
import UIKit
import HandyJSON
struct ZLMSaleColumns: HandyJSON {
var code: Int?
var codeMessage: String?
var type: String?
var list:[ZLMSaleModel]?
required init(){}
图片数组的model
import UIKit
import HandyJSON
struct ZLMSaleModel: HandyJSON {
var pic :String?
required init(){}
从上看出通过HandyJSON建立的model有个固定格式
import UIKit
import HandyJSON
struct model名:HandyJSON{
你所需要的字段
required init(){} |
