Linux系统调用始末(2)
Linux系统调用始末(2)
syscall_exit:
        LOCKDEP_SYS_EXIT
        DISABLE_INTERRUPTS(CLBR_ANY)    # make sure we don't miss an interrupt
                                        # setting need_resched or sigpending
                                        # between sampling and the iret
        TRACE_IRQS_OFF
        movl TI_flags(%ebp), %ecx
        testl $_TIF_ALLWORK_MASK, %ecx  # current->work
        jne syscall_exit_work
接下来,代码的运行过程,像是进入了一个混沌世界。
通过跟踪,可以发现,大概系统执行了INTERRUPT_RETURN之后便返回了。
