哨兵模式
<?xml version="1.0" encoding="UTF-8"?>
<beans xmlns="http://www.springframework.org/schema/beans"
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:p="http://www.springframework.org/schema/p"
xmlns:context="http://www.springframework.org/schema/context"
xsi:schemaLocation="http://www.springframework.org/schema/context
http://www.springframework.org/s ... ing-context-2.5.xsd
http://www.springframework.org/schema/beans http://www.springframework.org/schema/beans/spring-beans.xsd">
<!--引入redis配置文件 -->
<bean
class="org.springframework.beans.factory.config.PropertyPlaceholderConfigurer">
<property name="locations">
<list>
<value>classpath:redis.properties</value>
</list>
</property>
</bean>
<!--连接池 属性定义 -->
<bean id="jedisPoolConfig" class="redis.clients.jedis.JedisPoolConfig">
<property name="maxActive" value="${redis.maxActive}" />
<property name="maxIdle" value="${redis.maxIdle}" />
<property name="maxWait" value="${redis.maxWait}" />
<property name="testOnBorrow" value="${redis.testOnBorrow}" />
</bean>
<!-- 哨兵模式 -->
<bean id="redisSentinelConfiguration"
class="org.springframework.data.redis.connection.RedisSentinelConfiguration">
<property name="master">
<bean class="org.springframework.data.redis.connection.RedisNode">
<property name="name" value="mymaster">
</property>
</bean>
</property>
<property name="sentinels">
<set>
<constructor-arg name="host" value="${redis.sentinel.master.host}" />
<constructor-arg name="port" value="${redis.sentinel.master.port}" />
</bean>
<constructor-arg name="host" value="${redis.sentinel.slave1.host}" />
<constructor-arg name="port" value="${redis.sentinel.slave1.port}" />
</bean>
<bean class="org.springframework.data.redis.connection.RedisNode ">
<constructor-arg name="host" value="${redis.sentinel.slave2.host}" />
<constructor-arg name="port" value="${redis.sentinel.slave2.port}" />
</bean>
</set>
</property>
</bean>
<!--定义连接工厂 -->
<bean id="jedisConnFactory"
class="org.springframework.data.redis.connection.jedis.JedisConnectionFactory">
<constructor-arg name="sentinelConfig" ref="redisSentinelConfiguration" />
<constructor-arg name="poolConfig" ref="jedisPoolConfig" />
<property name="database" value="${redis.database}" />
<property name="password" value="${redis.pass}" />
<property name="timeout" value="${redis.timeout}" />
</bean>
<!-- redis 模板 -->
<bean id="redisTemplate" class="org.springframework.data.redis.core.RedisTemplate"
p:connectionFactory-ref="jedisConnFactory" p:enableTransactionSupport="true">
<property name="keySerializer">
<bean
class="org.springframework.data.redis.serializer.StringRedisSerializer" />
</property>
<property name="valueSerializer">
<bean
</property>
<property name="hashKeySerializer">
<bean
</property>
<property name="hashValueSerializer">
<bean
</property>
</bean>
</beans> |
