Redis使用建议规范(7)
Redis使用建议规范(7)
集群模式
    <?xml version="1.0" encoding="UTF-8"?>
    <beans xmlns="http://www.springframework.org/schema/beans"
        xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:p="http://www.springframework.org/schema/p"
        xmlns:context="http://www.springframework.org/schema/context"
        xsi:schemaLocation="http://www.springframework.org/schema/context
               http://www.springframework.org/s ... ing-context-2.5.xsd
            http://www.springframework.org/schema/beans http://www.springframework.org/schema/beans/spring-beans.xsd">
        <!--引入redis配置文件 -->
        <bean
            class="org.springframework.beans.factory.config.PropertyPlaceholderConfigurer">
            <property name="locations">
                <list>
                    <value>classpath:redis.properties</value>
                </list>
            </property>
        </bean>
        <!--连接池 属性定义 -->
        <bean id="jedisPoolConfig" class="redis.clients.jedis.JedisPoolConfig">
            <property name="maxActive" value="${redis.maxActive}" />
            <property name="maxIdle" value="${redis.maxIdle}" />
            <property name="maxWait" value="${redis.maxWait}" />
            <property name="testOnBorrow" value="${redis.testOnBorrow}" />
        </bean>
        <!-- 集群模式 -->
        <bean id="redisClusterConfiguration"
            class="org.springframework.data.redis.connection.RedisClusterConfiguration">
            <property name="maxRedirects" value="${redis.maxRedirects}"></property>
            <property name="clusterNodes">
                <set>
                    <bean class="org.springframework.data.redis.connection.RedisClusterNode">
                        <constructor-arg name="host" value="${redis.cluster.host1}"/>
                        <constructor-arg name="port" value="${redis.cluster.port1}"/>
                    </bean>
                        <constructor-arg name="host" value="${redis.cluster.host2}"/>
                        <constructor-arg name="port" value="${redis.cluster.port2}"/>
                    </bean>
                        <constructor-arg name="host" value="${redis.cluster.host3}"/>
                        <constructor-arg name="port" value="${redis.cluster.port3}"/>
                    </bean>
                </set>
            </property>
        </bean>
        <!--定义连接工厂 -->
        <bean id="jedisConnFactory"
            class="org.springframework.data.redis.connection.jedis.JedisConnectionFactory">
            <constructor-arg name="clusterConfig" ref="redisClusterConfiguration" />
            <constructor-arg name="poolConfig" ref="jedisPoolConfig" />
            <property name="database" value="${redis.database}" />
            <property name="password" value="${redis.pass}" />
            <property name="timeout" value="${redis.timeout}" />
        </bean>
        <!-- redis 模板 -->
        <bean id="redisTemplate" class="org.springframework.data.redis.core.RedisTemplate"
            p:connectionFactory-ref="jedisConnFactory" p:enableTransactionSupport="true">
            <property name="keySerializer">
                <bean
                    class="org.springframework.data.redis.serializer.StringRedisSerializer" />
            </property>
            <property name="valueSerializer">
                <bean
            </property>
            <property name="hashKeySerializer">
                <bean
            </property>
            <property name="hashValueSerializer">
                <bean
            </property>
        </bean>
    </beans>
