HMSegmentedControl源代码解析(1)
HMSegmentedControl是一款选项卡的三方框架,github上有3000星左右。
研究了一下源码,并添加了一点注释。
HMSegmentedControl基于UIControl,上面有一个UIScrollView。
文字,图片,指示器都是用CALayer,UIBezierPath处理创建的。
// HMSegmentedControl.h
// Created by Hesham Abd-Elmegid on 23/12/12.
// Copyright (c) 2012-2015 Hesham Abd-Elmegid. All rights reserved.
#import <UIKit/UIKit.h>
@class HMSegmentedControl;
//点击按钮的block
typedef void (^IndexChangeBlock)(NSInteger index);
//Title富文本
typedef NSAttributedString *(^HMTitleFormatterBlock)(HMSegmentedControl *segmentedControl, NSString *title, NSUInteger index, BOOL selected);
//指示器的样式
typedef NS_ENUM(NSInteger, HMSegmentedControlSelectionStyle) {
//指示器和文字同宽
HMSegmentedControlSelectionStyleTextWidthStripe, // Indicator width will only be as big as the text width
//指示器和segment同宽
HMSegmentedControlSelectionStyleFullWidthStripe, // Indicator width will fill the whole segment
//矩形指示器
HMSegmentedControlSelectionStyleBox, // A rectangle that covers the whole segment
//箭头指示器
HMSegmentedControlSelectionStyleArrow // An arrow in the middle of the segment pointing up or down depending on `HMSegmentedControlSelectionIndicatorLocation`
//指示器位置样式
typedef NS_ENUM(NSInteger, HMSegmentedControlSelectionIndicatorLocation) {
//上
HMSegmentedControlSelectionIndicatorLocationUp,
//下
HMSegmentedControlSelectionIndicatorLocationDown,
//无
HMSegmentedControlSelectionIndicatorLocationNone // No selection indicator
typedef NS_ENUM(NSInteger, HMSegmentedControlSegmentWidthStyle) {
//宽度fix
HMSegmentedControlSegmentWidthStyleFixed, // Segment width is fixed
//segment的宽度和text的宽度一致
HMSegmentedControlSegmentWidthStyleDynamic, // Segment width will only be as big as the text width (including inset)
//边框类型
typedef NS_OPTIONS(NSInteger, HMSegmentedControlBorderType) {
HMSegmentedControlBorderTypeNone = 0,
HMSegmentedControlBorderTypeTop = (1 << 0),
HMSegmentedControlBorderTypeLeft = (1 << 1),
HMSegmentedControlBorderTypeBottom = (1 << 2),
HMSegmentedControlBorderTypeRight = (1 << 3)
enum {
HMSegmentedControlNoSegment = -1 // Segment index for no selected segment
//segment类型
typedef NS_ENUM(NSInteger, HMSegmentedControlType) {
//文本
HMSegmentedControlTypeText,
//图片
HMSegmentedControlTypeImages,
//图文
HMSegmentedControlTypeTextImages
@interface HMSegmentedControl : UIControl |
