HMSegmentedControl源代码解析(2)
@property (nonatomic, strong) NSArray<NSString *> *sectionTitles; // section标题
@property (nonatomic, strong) NSArray<UIImage *> *sectionImages; // section图片
@property (nonatomic, strong) NSArray<UIImage *> *sectionSelectedImages; // 选中的section图片
Provide a block to be executed when selected index is changed.
Alternativly, you could use `addTarget:action:forControlEvents:`
选中index之后的回调
可以使用`addTarget:action:forControlEvents:`替代
@property (nonatomic, copy) IndexChangeBlock indexChangeBlock;
Used to apply custom text styling to titles when set.
When this block is set, no additional styling is applied to the `NSAttributedString` object returned from this block.
自定义富文本标题
@property (nonatomic, copy) HMTitleFormatterBlock titleFormatter;
Text attributes to apply to item title text.
标题 text 属性
@property (nonatomic, strong) NSDictionary *titleTextAttributes UI_APPEARANCE_SELECTOR;
Text attributes to apply to selected item title text.
Attributes not set in this dictionary are inherited from `titleTextAttributes`.
@property (nonatomic, strong) NSDictionary *selectedTitleTextAttributes UI_APPEARANCE_SELECTOR;
Segmented control background color.
Default is `[UIColor whiteColor]`
背景颜色
@property (nonatomic, strong) UIColor *backgroundColor UI_APPEARANCE_SELECTOR;
Color for the selection indicator stripe
Default is `R:52, G:181, B:229`
指示器颜色
@property (nonatomic, strong) UIColor *selectionIndicatorColor UI_APPEARANCE_SELECTOR;
Color for the selection indicator box
Default is selectionIndicatorColor
box颜色
