HMSegmentedControl源代码解析(3)
@property (nonatomic, strong) UIColor *selectionIndicatorBoxColor UI_APPEARANCE_SELECTOR;
Color for the vertical divider between segments.
Default is `[UIColor blackColor]`
segment间的分割线的颜色
@property (nonatomic, strong) UIColor *verticalDividerColor UI_APPEARANCE_SELECTOR;
Opacity for the seletion indicator box.
Default is `0.2f`
不透明的盒子对比指标
@property (nonatomic) CGFloat selectionIndicatorBoxOpacity;
Width the vertical divider between segments that is added when `verticalDividerEnabled` is set to YES.
Default is `1.0f`
分割线高度
@property (nonatomic, assign) CGFloat verticalDividerWidth;
Specifies the style of the control
Default is `HMSegmentedControlTypeText`
@property (nonatomic, assign) HMSegmentedControlType type;
Specifies the style of the selection indicator.
Default is `HMSegmentedControlSelectionStyleTextWidthStripe`
@property (nonatomic, assign) HMSegmentedControlSelectionStyle selectionStyle;
Specifies the style of the segment's width.
Default is `HMSegmentedControlSegmentWidthStyleFixed`
@property (nonatomic, assign) HMSegmentedControlSegmentWidthStyle segmentWidthStyle;
Specifies the location of the selection indicator.
Default is `HMSegmentedControlSelectionIndicatorLocationUp`
@property (nonatomic, assign) HMSegmentedControlSelectionIndicatorLocation selectionIndicatorLocation;
Specifies the border type.
Default is `HMSegmentedControlBorderTypeNone`
@property (nonatomic, assign) HMSegmentedControlBorderType borderType;
Specifies the border color.
@property (nonatomic, strong) UIColor *borderColor;
Specifies the border width.
Default is `1.0f`
边框颜色
@property (nonatomic, assign) CGFloat borderWidth;
Default is YES. Set to NO to deny scrolling by dragging the scrollView by the user.
是否可以拖拽
@property(nonatomic, getter = isUserDraggable) BOOL userDraggable;
Default is YES. Set to NO to deny any touch events by the user.
是否可以点击
@property(nonatomic, getter = isTouchEnabled) BOOL touchEnabled;
Default is NO. Set to YES to show a vertical divider between the segments.
