HMSegmentedControl源代码解析(6)
@interface HMSegmentedControl ()
//3中不同的指示器的layer
@property (nonatomic, strong) CALayer *selectionIndicatorStripLayer;
@property (nonatomic, strong) CALayer *selectionIndicatorBoxLayer;
@property (nonatomic, strong) CALayer *selectionIndicatorArrowLayer;
@property (nonatomic, readwrite) CGFloat segmentWidth;
@property (nonatomic, readwrite) NSArray<NSNumber *> *segmentWidthsArray;
@property (nonatomic, strong) HMScrollView *scrollView;
@end
@implementation HMSegmentedControl
#pragma mark - 初始化
- (id)initWithCoder NSCoder *)aDecoder {
self = [super initWithCoder:aDecoder];
if (self) {
[self commonInit];
return self;
- (id)initWithFrame CGRect)frame {
self = [super initWithFrame:frame];
if (self) {
[self commonInit];
return self;
- (id)initWithSectionTitles NSArray<NSString *> *)sectiontitles {
self = [super initWithFrame:CGRectZero];
if (self) {
[self commonInit];
self.sectionTitles = sectiontitles;
self.type = HMSegmentedControlTypeText;
return self;
- (id)initWithSectionImages NSArray<UIImage *> *)sectionImages sectionSelectedImages NSArray<UIImage *> *)sectionSelectedImages {
if (self) {
[self commonInit];
self.sectionImages = sectionImages;
self.sectionSelectedImages = sectionSelectedImages;
self.type = HMSegmentedControlTypeImages;
return self;
- (instancetype)initWithSectionImages NSArray<UIImage *> *)sectionImages sectionSelectedImages NSArray<UIImage *> *)sectionSelectedImages titlesForSections NSArray<NSString *> *)sectiontitles {
if (self) {
[self commonInit];
if (sectionImages.count != sectiontitles.count) {
//报错信息
[NSException raise:NSRangeException format "***%s: Images bounds (%ld) Don't match Title bounds (%ld)", sel_getName(_cmd), (unsigned long)sectionImages.count, (unsigned long)sectiontitles.count];
self.type = HMSegmentedControlTypeTextImages;
return self;
- (void)awakeFromNib {
[super awakeFromNib];
self.segmentWidth = 0.0f;
#pragma mark - createView
初始化界面与参数
- (void)commonInit {
//创建底层scrollview
self.scrollView = [[HMScrollView alloc] init];
self.scrollView.scrollsToTop = NO;
self.scrollView.showsVerticalScrollIndicator = NO;
self.scrollView.showsHorizontalScrollIndicator = NO;
[self addSubview:self.scrollView];
_backgroundColor = [UIColor whiteColor];
//opaque也是表示当前的UIView的不透明度,设置是否之后对于UIView的显示并没有什么影响,官方文档的意思简单点说就是opaque默认为YES,如果alpha小于1,那么应该设置opaque设置为NO,但是如果alpha为1,opaque设置为NO,产生的后果是不可预料的~
self.opaque = NO;
//设置指示器背景颜色
_selectionIndicatorColor = [UIColor colorWithRed:52.0f/255.0f green:181.0f/255.0f blue:229.0f/255.0f alpha:1.0f];
_selectionIndicatorBoxColor = _selectionIndicatorColor;
//默认选中0
self.selectedSegmentIndex = 0;
self.segmentEdgeInset = UIEdgeInsetsMake(0, 5, 0, 5);
self.selectionIndicatorHeight = 5.0f;
self.selectionIndicatorEdgeInsets = UIEdgeInsetsMake(0.0f, 0.0f, 0.0f, 0.0f);
self.selectionStyle = HMSegmentedControlSelectionStyleTextWidthStripe;
self.selectionIndicatorLocation = HMSegmentedControlSelectionIndicatorLocationUp;
self.segmentWidthStyle = HMSegmentedControlSegmentWidthStyleFixed;
self.userDraggable = YES;
self.touchEnabled = YES;
self.verticalDividerEnabled = NO;
self.verticalDividerWidth = 1.0f;
_verticalDividerColor = [UIColor blackColor];
self.borderColor = [UIColor blackColor];
self.borderWidth = 1.0f;
self.shouldAnimateUserSelection = YES; |
