问题描述
其他业务线的同学在测试环境发现应用程序一直不能获取redis连接,我帮忙看了下。
首先看应用错误日志
Caused by: org.springframework.data.redis.RedisConnectionFailureException: Cannot get Jedis connection; nested exception is redis.clients.jedis.exceptions.JedisConnectionException: Could not get a resource from the pool
at org.springframework.data.redis.connection.jedis.JedisConnectionFactory.fetchJedisConnector(JedisConnectionFactory.java:97)
at org.springframework.data.redis.connection.jedis.JedisConnectionFactory.getConnection(JedisConnectionFactory.java:143)
at org.springframework.data.redis.connection.jedis.JedisConnectionFactory.getConnection(JedisConnectionFactory.java:41)
at org.springframework.data.redis.core.RedisConnectionUtils.doGetConnection(RedisConnectionUtils.java:85)
at org.springframework.data.redis.core.RedisConnectionUtils.getConnection(RedisConnectionUtils.java:55)
at org.springframework.data.redis.core.RedisTemplate.execute(RedisTemplate.java:169)
at org.springframework.data.redis.core.RedisTemplate.execute(RedisTemplate.java:149)
... 76 more
Caused by: redis.clients.jedis.exceptions.JedisConnectionException: Could not get a resource from the pool
at redis.clients.util.Pool.getResource(Pool.java:22)
at org.springframework.data.redis.connection.jedis.JedisConnectionFactory.fetchJedisConnector(JedisConnectionFactory.java:90)
... 83 more
Caused by: java.util.NoSuchElementException: Could not create a validated object, cause: ValidateObject failed
at org.apache.commons.pool.impl.GenericObjectPool.borrowObject(GenericObjectPool.java:871)
at redis.clients.util.Pool.getResource(Pool.java:20)
... 84 more
问题调查
确定环境
发现是使用spring-data-redis通过jedis连接的redis服务端。
这个系统的代码很久没动,已经忘记了。先看看使用的jar版本吧。
查看应用程序使用的相关jar:
lsof -p 19377 | grep -E "jedis|pool|redis"
发现输出的jar包含:commons-pool-1.3.jar、spring-data-redis-1.1.1.RELEASE.jar、jedis-2.1.0.jar
翻了下commons pool相关代码
try {
_factory.activateObject(latch.getPair().value);
if(_testOnBorrow &&
!_factory.validateObject(latch.getPair().value)) {
throw new Exception("ValidateObject failed");
synchronized(this) {
_numInternalProcessing--;
_numActive++;
return latch.getPair().value;
catch (Throwable e) {
PoolUtils.checkRethrow(e);
// object cannot be activated or is invalid
try {
_factory.destroyObject(latch.getPair().value);
} catch (Throwable e2) {
PoolUtils.checkRethrow(e2);
// cannot destroy broken object
synchronized (this) {
if (!newlyCreated) {
latch.reset();
_allocationQueue.add(0, latch);
allocate();
if(newlyCreated) {
throw new NoSuchElementException("Could not create a validated object, cause: " + e.getMessage());
else {
continue; // keep looping
可见客户端应该是配置了testOnBorrow,在校验连接时失败了。
java操作redis有多种客户端,项目使用spring-data-redis操作redis,在spring-data-redis中也有不同的客户端实现如jedis,lettuce等。根据错误日志推断使用的redis客户端实现为jedis。
查看JedisConnectionFactory源码
在JedisPool中定义了校验对象的代码。
public boolean validateObject(final Object obj) {
if (obj instanceof Jedis) {
final Jedis jedis = (Jedis) obj;
try {
return jedis.isConnected() && jedis.ping().equals("PONG");
} catch (final Exception e) {
return false;
} else {
return false;
