Android中实现Toast效果Dialog自动消失
1、核心代码
    public class ToastDialog extends Dialog {
        public static final int DIALOG_SHOW_TIME_SHORT = 3000;
        public static final int DIALOG_SHOW_TIME_LONG = 5000;
         * 显示时间,单位毫秒,默认3秒
        private int showTime = DIALOG_SHOW_TIME_SHORT;
        private int toastDialogTioIconId = 0;
        private Object toastShowContent;
        public ToastDialog(Context context) {
            super(context, R.style.style_dialog);
        @Override
        protected void onCreate(Bundle savedInstanceState) {
            super.onCreate(savedInstanceState);
            setCanceledOnTouchOutside(false);
            setCancelable(false);
            setContentView(R.layout.dialog_customize_toast);
            initView();
        private void initView() {
            ImageView ivToastDialogIcon = (ImageView) findViewById(R.id.iv_dialog_toast_icon);
            if (getToastDialogTioIconId() != 0) {
                ivToastDialogIcon.setImageResource(getToastDialogTioIconId());
            TextView tvToastDialogContent = (TextView) findViewById(R.id.tv_dialog_toast_content);
            ViewUtils.loadContent(tvToastDialogContent, getToastShowContent());
        @Override
        public void show() {
            dismissDialog();
            super.show();
        private void dismissDialog() {
            Timer timer = new Timer();
            timer.schedule(new TimerTask() {
                @Override
                public void run() {
                    dismiss();
            }, getShowTime());
        @Override
        public void dismiss() {
            super.dismiss();
        @Override
        public void onBackPressed() {
            return;
        private int getShowTime() {
            return showTime;
         * 设置显示时间,单位毫秒
         * @param showTime 时间
        public void setShowTime(int showTime) {
            this.showTime = showTime;
        private int getToastDialogTioIconId() {
            return toastDialogTioIconId;
         * 设置显示图标
         * @param toastDialogTioIconId 图标ID
        public void setToastDialogTioIconId(int toastDialogTioIconId) {
            this.toastDialogTioIconId = toastDialogTioIconId;
        private Object getToastShowContent() {
            return toastShowContent;
         * 显示内容
         * @param toastShowContent 内容
        public void setToastShowContent(Object toastShowContent) {
            this.toastShowContent = toastShowContent;
