ACache缓存框架工具类(1)
ACache缓存框架工具类(1)
* Copyright (c) 2012-2013, Michael Yang 杨福海 (www.yangfuhai.com).
* <p>
* Licensed under the Apache License, Version 2.0 (the "License");
* you may not use this file except in compliance with the License.
* You may obtain a copy of the License at
* <p>
* http://www.apache.org/licenses/LICENSE-2.0
* <p>
* Unless required by applicable law or agreed to in writing, software
* distributed under the License is distributed on an "AS IS" BASIS,
* WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
* See the License for the specific language governing permissions and
* limitations under the License.
package com.hwc.oklib.util;
import android.content.Context;
import android.graphics.Bitmap;
import android.graphics.BitmapFactory;
import android.graphics.Canvas;
import android.graphics.PixelFormat;
import android.graphics.drawable.BitmapDrawable;
import android.graphics.drawable.Drawable;
import org.json.JSONArray;
import org.json.JSONObject;
import java.io.BufferedReader;
import java.io.BufferedWriter;
import java.io.ByteArrayInputStream;
import java.io.ByteArrayOutputStream;
import java.io.File;
import java.io.FileOutputStream;
import java.io.FileReader;
import java.io.FileWriter;
import java.io.IOException;
import java.io.ObjectInputStream;
import java.io.ObjectOutputStream;
import java.io.RandomAccessFile;
import java.io.Serializable;
import java.util.Collections;
import java.util.HashMap;
import java.util.Map;
import java.util.Map.Entry;
import java.util.Set;
import java.util.concurrent.atomic.AtomicInteger;
import java.util.concurrent.atomic.AtomicLong;
* 创建时间:2016/6/27
* 编写者:黄伟才
* 功能描述:ASimpleCache是一个为android制定的轻量级的开源缓存框架
* (替换SharePreference当做配置文件)
public class ACache {
    public static final int TIME_HOUR = 60 * 60;
    public static final int TIME_DAY = TIME_HOUR * 24;
    private static final int MAX_SIZE = 1000 * 1000 * 50; // 50 mb
    private static final int MAX_COUNT = Integer.MAX_VALUE; // 不限制存放数据的数量
    private static Map<String, ACache> mInstanceMap = new HashMap<String, ACache>();
    private ACacheManager mCache;
    public static ACache get(Context ctx) {
        return get(ctx, "ACache");
    public static ACache get(Context ctx, String cacheName) {
        File f = new File(ctx.getCacheDir(), cacheName);
        return get(f, MAX_SIZE, MAX_COUNT);
    public static ACache get(File cacheDir) {
        return get(cacheDir, MAX_SIZE, MAX_COUNT);
    public static ACache get(Context ctx, long max_zise, int max_count) {
        File f = new File(ctx.getCacheDir(), "ACache");
        return get(f, max_zise, max_count);
    public static ACache get(File cacheDir, long max_zise, int max_count) {
        ACache manager = mInstanceMap.get(cacheDir.getAbsoluteFile() + myPid());
        if (manager == null) {
            manager = new ACache(cacheDir, max_zise, max_count);
            mInstanceMap.put(cacheDir.getAbsolutePath() + myPid(), manager);
        return manager;
    private static String myPid() {
        return "_" + android.os.Process.myPid();
    private ACache(File cacheDir, long max_size, int max_count) {
        if (!cacheDir.exists() && !cacheDir.mkdirs()) {
            throw new RuntimeException("can't make dirs in "
                    + cacheDir.getAbsolutePath());
        mCache = new ACacheManager(cacheDir, max_size, max_count);
    // ============ String数据 读写 ==============
     * 保存 String数据 到 缓存中
     * @param key
     *            保存的key
     * @param value
     *            保存的String数据
    public void put(String key, String value) {
        File file = mCache.newFile(key);
        BufferedWriter out = null;
        try {
            out = new BufferedWriter(new FileWriter(file), 1024);
            out.write(value);
        } catch (IOException e) {
            e.printStackTrace();
        } finally {
            if (out != null) {
                try {
                    out.flush();
                    out.close();
            mCache.put(file);
