// ============= 序列化 数据 读写 ===============
* 保存 Serializable数据 到 缓存中
* @param key
* 保存的key
* @param value
* 保存的value
public void put(String key, Serializable value) {
put(key, value, -1);
* 保存 Serializable数据到 缓存中
* @param key
* 保存的key
* @param value
* 保存的value
* @param saveTime
* 保存的时间,单位:秒
public void put(String key, Serializable value, int saveTime) {
ByteArrayOutputStream baos = null;
ObjectOutputStream oos = null;
try {
baos = new ByteArrayOutputStream();
oos = new ObjectOutputStream(baos);
oos.writeObject(value);
byte[] data = baos.toByteArray();
if (saveTime != -1) {
put(key, data, saveTime);
} else {
put(key, data);
} catch (Exception e) {
e.printStackTrace();
} finally {
try {
oos.close();
} catch (IOException e) {
* 读取 Serializable数据
* @param key
* @return Serializable 数据
public Object getAsObject(String key) {
byte[] data = getAsBinary(key);
if (data != null) {
ByteArrayInputStream bais = null;
ObjectInputStream ois = null;
try {
bais = new ByteArrayInputStream(data);
ois = new ObjectInputStream(bais);
Object reObject = ois.readObject();
return reObject;
return null;
} finally {
try {
if (bais != null)
bais.close();
try {
if (ois != null)
ois.close();
return null;
