* 保存 drawable 到 缓存中
* @param key
* 保存的key
* @param value
* 保存的 drawable 数据
* @param saveTime
* 保存的时间,单位:秒
public void put(String key, Drawable value, int saveTime) {
put(key, Utils.drawable2Bitmap(value), saveTime);
* 读取 Drawable 数据
* @param key
* @return Drawable 数据
public Drawable getAsDrawable(String key) {
if (getAsBinary(key) == null) {
return null;
return Utils.bitmap2Drawable(Utils.Bytes2Bimap(getAsBinary(key)));
* 获取缓存文件
* @param key
* @return value 缓存的文件
public File file(String key) {
File f = mCache.newFile(key);
if (f.exists())
return f;
return null;
* 移除某个key
* @param key
* @return 是否移除成功
public boolean remove(String key) {
return mCache.remove(key);
* 清除所有数据
public void clear() {
mCache.clear();
* @title 缓存管理器
* @author 杨福海(michael) www.yangfuhai.com
* @version 1.0
public class ACacheManager {
private final AtomicLong cacheSize;
private final AtomicInteger cacheCount;
private final long sizeLimit;
private final int countLimit;
private final Map<File, Long> lastUsageDates = Collections
.synchronizedMap(new HashMap<File, Long>());
protected File cacheDir;
private ACacheManager(File cacheDir, long sizeLimit, int countLimit) {
this.cacheDir = cacheDir;
this.sizeLimit = sizeLimit;
this.countLimit = countLimit;
cacheSize = new AtomicLong();
cacheCount = new AtomicInteger();
calculateCacheSizeAndCacheCount();
* 计算 cacheSize和cacheCount
private void calculateCacheSizeAndCacheCount() {
new Thread(new Runnable() {
@Override
public void run() {
int size = 0;
int count = 0;
File[] cachedFiles = cacheDir.listFiles();
if (cachedFiles != null) {
for (File cachedFile : cachedFiles) {
size += calculateSize(cachedFile);
count += 1;
lastUsageDates.put(cachedFile,
cachedFile.lastModified());
cacheSize.set(size);
cacheCount.set(count);
}).start();
private void put(File file) {
int curCacheCount = cacheCount.get();
while (curCacheCount + 1 > countLimit) {
long freedSize = removeNext();
cacheSize.addAndGet(-freedSize);
curCacheCount = cacheCount.addAndGet(-1);
cacheCount.addAndGet(1);
long valueSize = calculateSize(file);
long curCacheSize = cacheSize.get();
while (curCacheSize + valueSize > sizeLimit) {
curCacheSize = cacheSize.addAndGet(-freedSize);
cacheSize.addAndGet(valueSize);
Long currentTime = System.currentTimeMillis();
file.setLastModified(currentTime);
lastUsageDates.put(file, currentTime);
private File get(String key) {
File file = newFile(key);
return file;
private File newFile(String key) {
return new File(cacheDir, key.hashCode() + "");
private boolean remove(String key) {
File image = get(key);
return image.delete();
private void clear() {
lastUsageDates.clear();
cacheSize.set(0);
File[] files = cacheDir.listFiles();
if (files != null) {
for (File f : files) {
f.delete();
