ACache缓存框架工具类(8)
ACache缓存框架工具类(8)
     * @title 时间计算工具类
     * @author 杨福海(michael) www.yangfuhai.com
     * @version 1.0
    private static class Utils {
         * 判断缓存的String数据是否到期
         * @param str
         * @return true:到期了 false:还没有到期
        private static boolean isDue(String str) {
            return isDue(str.getBytes());
         * 判断缓存的byte数据是否到期
         * @param data
        private static boolean isDue(byte[] data) {
            String[] strs = getDateInfoFromDate(data);
            if (strs != null && strs.length == 2) {
                String saveTimeStr = strs[0];
                while (saveTimeStr.startsWith("0")) {
                    saveTimeStr = saveTimeStr
                            .substring(1, saveTimeStr.length());
                long saveTime = Long.valueOf(saveTimeStr);
                long deleteAfter = Long.valueOf(strs[1]);
                if (System.currentTimeMillis() > saveTime + deleteAfter * 1000) {
                    return true;
            return false;
        private static String newStringWithDateInfo(int second, String strInfo) {
            return createDateInfo(second) + strInfo;
        private static byte[] newByteArrayWithDateInfo(int second, byte[] data2) {
            byte[] data1 = createDateInfo(second).getBytes();
            byte[] retdata = new byte[data1.length + data2.length];
            System.arraycopy(data1, 0, retdata, 0, data1.length);
            System.arraycopy(data2, 0, retdata, data1.length, data2.length);
            return retdata;
        private static String clearDateInfo(String strInfo) {
            if (strInfo != null && hasDateInfo(strInfo.getBytes())) {
                strInfo = strInfo.substring(strInfo.indexOf(mSeparator) + 1,
                        strInfo.length());
            return strInfo;
        private static byte[] clearDateInfo(byte[] data) {
            if (hasDateInfo(data)) {
                return copyOfRange(data, indexOf(data, mSeparator) + 1,
                        data.length);
            return data;
        private static boolean hasDateInfo(byte[] data) {
            return data != null && data.length > 15 && data[13] == '-'
                    && indexOf(data, mSeparator) > 14;
        private static String[] getDateInfoFromDate(byte[] data) {
                String saveDate = new String(copyOfRange(data, 0, 13));
                String deleteAfter = new String(copyOfRange(data, 14,
                        indexOf(data, mSeparator)));
                return new String[] { saveDate, deleteAfter };
            return null;
        private static int indexOf(byte[] data, char c) {
            for (int i = 0; i < data.length; i++) {
                if (data == c) {
                    return i;
            return -1;
        private static byte[] copyOfRange(byte[] original, int from, int to) {
            int newLength = to - from;
            if (newLength < 0)
                throw new IllegalArgumentException(from + " > " + to);
            byte[] copy = new byte[newLength];
            System.arraycopy(original, from, copy, 0,
                    Math.min(original.length - from, newLength));
            return copy;
        private static final char mSeparator = ' ';
        private static String createDateInfo(int second) {
            String currentTime = System.currentTimeMillis() + "";
            while (currentTime.length() < 13) {
                currentTime = "0" + currentTime;
            return currentTime + "-" + second + mSeparator;
