ACache缓存框架工具类(9)
ACache缓存框架工具类(9)
         * Bitmap → byte[]
        private static byte[] Bitmap2Bytes(Bitmap bm) {
            if (bm == null) {
                return null;
            ByteArrayOutputStream baos = new ByteArrayOutputStream();
            bm.compress(Bitmap.CompressFormat.PNG, 100, baos);
            return baos.toByteArray();
         * byte[] → Bitmap
        private static Bitmap Bytes2Bimap(byte[] b) {
            if (b.length == 0) {
                return null;
            return BitmapFactory.decodeByteArray(b, 0, b.length);
         * Drawable → Bitmap
        private static Bitmap drawable2Bitmap(Drawable drawable) {
            if (drawable == null) {
                return null;
            // 取 drawable 的长宽
            int w = drawable.getIntrinsicWidth();
            int h = drawable.getIntrinsicHeight();
            // 取 drawable 的颜色格式
            Bitmap.Config config = drawable.getOpacity() != PixelFormat.OPAQUE ? Bitmap.Config.ARGB_8888
                    : Bitmap.Config.RGB_565;
            // 建立对应 bitmap
            Bitmap bitmap = Bitmap.createBitmap(w, h, config);
            // 建立对应 bitmap 的画布
            Canvas canvas = new Canvas(bitmap);
            drawable.setBounds(0, 0, w, h);
            // 把 drawable 内容画到画布中
            drawable.draw(canvas);
            return bitmap;
         * Bitmap → Drawable
        @SuppressWarnings("deprecation")
        private static Drawable bitmap2Drawable(Bitmap bm) {
            if (bm == null) {
                return null;
            return new BitmapDrawable(bm);
