» Spring Boot 与 Kotlin 整合MyBatis(1)
look_w
233 小时
look_w
发表于 2019-3-4 20:53
创建项目,在build.gradle文件中引入依赖
compile "org.mybatis.spring.boot:mybatis-spring-boot-starter
mybatis_version"
compile "mysql:mysql-connector-java
mysql_version"
完整的build.gradle文件
group 'name.quanke.kotlin'
version '1.0-SNAPSHOT'
buildscript {
ext.kotlin_version = '1.2.10'
ext.spring_boot_version = '1.5.4.RELEASE'
ext.springfox_swagger2_version = '2.7.0'
ext.mysql_version = '5.1.21'
ext.mybatis_version = '1.1.1'
repositories {
mavenCentral()
dependencies {
classpath "org.jetbrains.kotlin:kotlin-gradle-plugin
kotlin_version"
classpath("org.springframework.boot:spring-boot-gradle-plugin
spring_boot_version")
// Kotlin整合SpringBoot的默认无参构造函数,默认把所有的类设置open类插件
classpath("org.jetbrains.kotlin:kotlin-noarg
kotlin_version")
classpath("org.jetbrains.kotlin:kotlin-allopen
kotlin_version")
apply plugin: 'kotlin'
apply plugin: "kotlin-spring" // See
https://kotlinlang.org/docs/refe ... ing-compiler-plugin
apply plugin: 'org.springframework.boot'
apply plugin: "kotlin-jpa" //https://stackoverflow.com/questions/32038177/kotlin-with-jpa-default-constructor-hell
jar {
baseName = 'chapter11-6-5-service'
version = '0.1.0'
repositories {
mavenCentral()
dependencies {
compile "org.jetbrains.kotlin:kotlin-stdlib-jre8
kotlin_version"
compile("org.jetbrains.kotlin:kotlin-reflect
{kotlin_version}")
mybatis_version"
mysql_version"
testCompile "org.springframework.boot:spring-boot-starter-test:$spring_boot_version"
testCompile "org.jetbrains.kotlin:kotlin-test-junit:$kotlin_version"
compileKotlin {
kotlinOptions.jvmTarget = "1.8"
compileTestKotlin {
