1.直接代码展示
(void)viewDidLoad
[super viewDidLoad];
NSLog(@"%@ call",NSStringFromSelector(_cmd));
输出结果如下:
2018-05-17 10:33:35.583110+0800 CoreGraphicsDemo_Example[99368:13538878] viewDidLoad call
_cmd在Objective-C的方法中表示当前方法的selector,正如同self表示当前方法调用的对象实例。
//比如需要打印当前被调用的方法,可以在一个方法中添加:
//会输出类似
//2013-01-10 11:25:46.902 TDDataViewer[855:303] applicationDidFinishLaunching: call
//这样的内容。
//在cocos2d中,_cmd通常用于定时调用某个函数(schedule)
//比如下面方法利用_cmd能够不定时地调用某个函数
-(void) scheduleUpdates {
// schedule the first update as usual
[self scheduleselector(irregularUpdate interval:1];
-(void) irregularUpdateccTime)delta {
// unschedule the method first [self unschedule:_cmd];
// I assume you’d have some kind of logic other than random to determine
// the next time the method should be called
float nextUpdate = CCRANDOM_0_1() * 10;
// then re-schedule it with the new interval using _cmd as the selector
[self schedule:_cmd interval:nextUpdate];
2.其他用法:
- (CustomNavigationControllerDelegate *)customDelegate
return objc_getAssociatedObject(self, _cmd);
- (void)setCustomDelegateCustomNavigationControllerDelegate *)customDelegate
objc_setAssociatedObject(self, @selector(customDelegate), customDelegate, OBJC_ASSOCIATION_RETAIN_NONATOMIC);
