Angular Directive 详解(5)
我们将上面的directive简单的改一下,
    myDirectives.directive('myAttr', function() {
        return {
            restrict: 'E',
            template: 'Name: {{customerInfo.name}} Address: {{customerInfo.address}}<br>' +
                      'Name: {{vojta.name}} Address: {{vojta.address}}'
    复制代码
    运行结果如下:
    Name: Vojta Address: 3456 Somewhere Else
    复制代码
    因为此时的directive没有定义独立的scope,customerInfo是undefined,所以结果正好与上面相反。
transclude的使用
    transclude的用法,有点像jquery里面的$().html()功能
    myDirective.directive('myEvent', function() {
        return {
            restrict: 'E',
            transclude: true,
            scope: {
                'close': '$onClick'      //根html中的on-click="hideDialog()"有关联关系
            templateUrl: '../partials/event_part.html'
    myController.controller('eventTest', [
        '$scope',
        '$timeout',
        function($scope, $timeout) {
            $scope.name = 'Tobias';
            $scope.hideDialog = function() {
                $scope.dialogIsHidden = true;
                $timeout(function() {
                    $scope.dialogIsHidden = false;
                }, 2000);
    复制代码
    <body ng-app="phonecatApp">
        <div ng-controller="eventtest">
            <my-event ng-hide="dialogIsHidden" on-click="hideDialog()">
                Check out the contents, {{name}}!
            </my-event>
        </div>
    </body>
    <!--event_part.html -->
    <div>
        <a href ng-click="close()">×</a>
        <div ng-transclude></div>
    </div>
    复制代码
    说明:这段html最终的结构应该如下所示:
            <div ng-hide="dialogIsHidden" on-click="hideDialog()">
                <span>Check out the contents, {{name}}!</span>
            </div>
        </div>
    </body>
    复制代码
    将原来的html元素中的元素Check out the contents, !插入到模版的
    中,还会另外附加一个标签。 controller,link,compile之间的关系
    myDirective.directive('exampleDirective', function() {
        return {
            restrict: 'E',
            template: '<p>Hello {{number}}!</p>',
            controller: function($scope, $element){
                $scope.number = $scope.number + "22222 ";
            link: function(scope, el, attr) {
                scope.number = scope.number + "33333 ";
            compile: function(element, attributes) {
                return {
                    pre: function preLink(scope, element, attributes) {
                        scope.number = scope.number + "44444 ";
                    post: function postLink(scope, element, attributes) {
                        scope.number = scope.number + "55555 ";
    //controller.js添加
    myController.controller('directive2',[
        '$scope',
        function($scope) {
            $scope.number = '1111 ';
    //html
    <body ng-app="testApp">
        <div ng-controller="directive2">
            <example-directive></example-directive>
        </div>
    </body>
    复制代码
    上面小例子的运行结果如下:
    Hello 1111 22222 44444 5555 !
    复制代码
    由结果可以看出来,controller先运行,compile后运行,link不运行。 我们现在将compile属性注释掉后,得到的运行结果如下: Hello 1111 22222 33333 !
