AutoreleasePool从入门到放弃(4)
autoreleaseNewPage(id obj)
    static __attribute__((noinline)) id *autoreleaseNewPage(id obj)
            AutoreleasePoolPage *page = hotPage();
            if (page) return autoreleaseFullPage(obj, page);
            else return autoreleaseNoPage(obj);
获取当前AutoreleasePoolPage,如果存在调用autoreleaseFullPage,否则调用autoreleaseNoPage
autoreleaseFullPage(id obj, AutoreleasePoolPage *page)
    static __attribute__((noinline)) id *autoreleaseFullPage(id obj, AutoreleasePoolPage *page)
            // The hot page is full.
            // Step to the next non-full page, adding a new page if necessary.
            // Then add the object to that page.
            assert(page == hotPage());
            assert(page->full()  ||  DebugPoolAllocation);
            do {
                if (page->child) page = page->child;
                else page = new AutoreleasePoolPage(page);
            } while (page->full());
            setHotPage(page);
            return page->add(obj);
遍历子AutoreleasePoolPage,如果有未满的AutoreleasePoolPage设置为当前AutoreleasePoolPage并调用add函数将对象入栈。否则将新创建的子AutoreleasePoolPage设置为当前AutoreleasePoolPage并调用add函数将对象入栈
add(id obj)
    id *add(id obj)
            assert(!full());
            unprotect();
            id *ret = next;  // faster than `return next-1` because of aliasing
            *next++ = obj;
            protect();
            return ret;
