2. iOS中的递归锁
同一个线程可以多次加锁,不会造成死锁
死锁->
- (void)lock5 {
NSLock *commonLock = [[NSLock alloc] init];
dispatch_async(dispatch_get_global_queue(DISPATCH_QUEUE_PRIORITY_DEFAULT, 0), ^{
static void (^XWRecursiveBlock)(int);
XWRecursiveBlock = ^(int value) {
[commonLock lock];
if (value > 0) {
NSLog(@"加锁层数: %d",value);
sleep(1);
XWRecursiveBlock(--value);
NSLog(@"程序退出!");
[commonLock unlock];
XWRecursiveBlock(3);
复制代码
<-死锁
2.1 NSRecursiveLock
- (void)lock4 {
NSRecursiveLock *recursiveLock = [[NSRecursiveLock alloc] init];
[recursiveLock lock];
if (value > 0) {
sleep(1);
NSLog(@"程序退出!");
[recursiveLock unlock];
复制代码
2.2 pthread
- (void)lock6 {
__block pthread_mutex_t recursiveMutex;
pthread_mutexattr_t recursiveMutexattr;
pthread_mutexattr_init(&recursiveMutexattr);
pthread_mutexattr_settype(&recursiveMutexattr, PTHREAD_MUTEX_RECURSIVE);
pthread_mutex_init(&recursiveMutex, &recursiveMutexattr);
pthread_mutex_lock(&recursiveMutex);
if (value > 0) {
sleep(1);
NSLog(@"程序退出!");
pthread_mutex_unlock(&recursiveMutex);
