搭建Harbor企业级docker仓库(6)
7.Harbor启动和停止
Harbor 的日常运维管理是通过docker-compose来完成的,Harbor本身有多个服务进程,都放在docker容器之中运行,我们可以通过docker ps命令查看。
    # docker ps
    CONTAINER ID        IMAGE                              COMMAND                  CREATED             STATUS              PORTS                                                              NAMES
    e6da3450bebe        vmware/harbor-jobservice:v1.2.0    "/harbor/harbor_jo..."   4 days ago          Up 4 days        harbor-jobservice6134227d7ed4        vmware/nginx-photon:1.11.13        "nginx -g 'daemon ..."   4 days ago          Up 4 days           0.0.0.0:80->80/tcp, 0.0.0.0:443->443/tcp, 0.0.0.0:4443->4443/tcp   nginx
    ef5fe0b856a7        vmware/harbor-ui:v1.2.0            "/harbor/harbor_ui"      4 days ago          Up 4 days        harbor-ui
    a752861c7e92        vmware/registry:2.6.2-photon       "/entrypoint.sh se..."   4 days ago          Up 4 days           5000/tcp                                                           registry78ea91838582        vmware/harbor-db:v1.2.0            "docker-entrypoint..."   4 days ago          Up 4 days           3306/tcp                                                           harbor-db024e226ff135        vmware/harbor-adminserver:v1.2.0   "/harbor/harbor_ad..."   4 days ago          Up 4 days        harbor-adminserver3fab80444a1d        vmware/harbor-log:v1.2.0           "/bin/sh -c 'crond..."   4 days ago          Up 4 days           127.0.0.1:1514->514/tcp                                            harbor-log
或者docker-compose 来查看
    # cd /usr/local/harbor/
    # docker-compose ps
           Name                     Command               State                                Ports
    harbor-adminserver   /harbor/harbor_adminserver       Up
    harbor-db            docker-entrypoint.sh mysqld      Up      3306/tcp
    harbor-jobservice    /harbor/harbor_jobservice        Up
    harbor-log           /bin/sh -c crond && rm -f  ...   Up      127.0.0.1:1514->514/tcp
    harbor-ui            /harbor/harbor_ui                Up
    nginx                nginx -g daemon off;             Up      0.0.0.0:443->443/tcp, 0.0.0.0:4443->4443/tcp, 0.0.0.0:80->80/tcp
    registry             /entrypoint.sh serve /etc/ ...   Up      5000/tcp
Harbor的启动和停止
    启动Harbor
    # docker-compose start
    停止Harbor
    # docker-comose stop
    重启Harbor
    # docker-compose restart
