node 实现WebSocket
node 实现WebSocket
WebSocket是什么?
WebSocket是一种网络通信协议,RFC6455定义了它的通信标准。
WebSocket是HTML5可以提供的一种在单个TCP连接上进行全双工通讯的协议。
服务器代码
    var express = require('express');
    var http = require('http');
    var WebSocket = require('ws');
    var app = express();
    app.use(express.static(__dirname));
    var server = http.createServer(app);
    var wss = new WebSocket.Server({server});
    wss.on('connection', function connection(ws) {
        console.log('开始连接!');
        ws.on('message', function incoming(data) {
             console.log('接收到了消息!');
             * 把消息发送到所有的客户端
             * wss.clients获取所有链接的客户端
            wss.clients.forEach(function each(client) {
                client.send(data);
    server.listen(8000, function listening() {
        console.log('服务器启动成功!');
客户端代码
    <!doctype html>
    <html lang="en">
    <head>
        <meta charset="UTF-8">
        <meta name="viewport"
     content="width=device-width, user-scalable=no, initial-scale=1.0, maximum-scale=1.0, minimum-scale=1.0">
        <meta http-equiv="X-UA-Compatible" content="ie=edge">
        <title>在线聊天</title>
    </head>
    <body>
    <input type="text">
    <script>
     var wsServer = new WebSocket('ws://127.0.0.1:8000');
     wsServer.onopen = function (e) {
         (typeof e == 'string') && wsServer.send(e);//向后台发送数据
     wsServer.onclose = function (e) {//当链接关闭的时候触发
     wsServer.onmessage = function (e) {//后台返回消息的时候触发
            console.log(e);
     wsServer.onerror = function (e) {//错误情况触发
    </script>
    </body>
    </html>
