ssm-购物车实现(2)
ssm-购物车实现(2)
package com.jt.cart.service;
    import java.util.List;
    import com.jt.common.po.Cart;
    public interface CartService {
        List<Cart> findCartByUserId(Long userId);
        void saveCart(Cart cart);
    import java.util.Date;
    import org.springframework.beans.factory.annotation.Autowired;
    import org.springframework.stereotype.Service;
    import com.jt.cart.mapper.CartMapper;
    @Service
    public class CartServiceImpl implements CartService {
        @Autowired
        private CartMapper cartMapper;
        @Override
        public List<Cart> findCartByUserId(Long userId) {
            Cart cart=new Cart();
            cart.setUserId(userId);
            return cartMapper.select(cart);
         * 根据userId和itemId判断数据库中是否有该购物车信息
         * 有
         *   数据库num+新num做更新操作
         * 没有数据
         *  应该插入数据库
        /* (non-Javadoc)
         * @see com.jt.cart.service.CartService#saveCart(com.jt.common.po.Cart)
        @Override
        public void saveCart(Cart cart) {
            Cart cartDB=cartMapper.findCartByUI(cart);
            if(cartDB==null){
                System.out.println("insert cart");
                cart.setCreated(new Date());
                cart.setUpdated(cart.getCreated());
                cartMapper.insert(cart);
            }else{
                System.out.println("insert cart2");
                int num=cartDB.getNum()+cart.getNum();
                cartDB.setNum(num);
                cartDB.setUpdated(new Date());
                cartMapper.updateByPrimaryKeySelective(cartDB);
