四、创建Pod代码库
有了仓库,我们就可以添加代码库啦。
4.1 使用pod创建库:
pod lib create EHIHiCarBluetooth
过程中终端会向我们提出一系列问题,大家自行选择即可。
4.2 添加文件,写好Demo
如图,添加文件:
工程目录如下:
在Example中写好Demo,保证编译运行ok。
4.3 编辑*.podspec
务必保证填写的每一项都要是正确的,比如主页和链接都要能够访问。
编辑EHIHiCarBluetooth.podspec文件如下:
# Be sure to run `pod lib lint EHIHiCarBluetooth.podspec' to ensure this is a
# valid spec before submitting.
# Any lines starting with a # are optional, but their use is encouraged
# To learn more about a Podspec see https://guides.cocoapods.org/syntax/podspec.html
Pod::Spec.new do |s|
s.name = 'EHIHiCarBluetooth'
s.version = '0.1.0'
s.summary = '一句话描述'
# This description is used to generate tags and improve search results.
# * Think: What does it do? Why did you write it? What is the focus?
# * Try to keep it short, snappy and to the point.
# * Write the description between the DESC delimiters below.
# * Finally, don't worry about the indent, CocoaPods strips it!
s.description = <<-DESC
TODO: Add long description of the pod here.
DESC
s.homepage = 'http://私有库地址/EHILibraryiOS/EHIHiCarBluetooth'
# s.screenshots = 'www.example.com/screenshots_1', 'www.example.com/screenshots_2'
s.license = { :type => 'MIT', :file => 'LICENSE' }
s.author = { '用户名' => '邮箱地址' }
s.source = { :git => 'http://私有库地址/EHILibraryiOS/EHIHiCarBluetooth.git', :tag => s.version.to_s }
# s.social_media_url = 'https://twitter.com/<TWITTER_USERNAME>'
s.ios.deployment_target = '8.0'
s.source_files = 'EHIHiCarBluetooth/Classes/*'
# s.resource_bundles = {
# 'EHIHiCarBluetooth' => ['EHIHiCarBluetooth/Assets/*.png']
# s.public_header_files = 'Pod/Classes/**/*.h'
# s.frameworks = 'UIKit', 'MapKit'
s.dependency 'YYKit'
s.dependency 'BabyBluetooth', '~> 0.7.0'
end |
