绑定端口并向Selector注册accept事件 3
public void bind(ChannelHandlerContext ctx, SocketAddress localAddress,
ChannelPromise promise) throws Exception {
ctx.bind(localAddress, promise);
走到这里其实我们发现了其实,还是回到了AbstractChannelHandlerContext#bind(),仍然是先调用了findContextOutbound(),那么其实,整个调用链会一直从pipeline.tail一直往上找到pipeline.head,查看前面章节初始化channel的过程,在实例化NioServerSocketChannel的时候,调用了父类的构造方法,其中AbstractChannel的构造方法实例化了pipeline
protected AbstractChannel(Channel parent) {
this.parent = parent;
id = newId();
unsafe = newUnsafe();
pipeline = newChannelPipeline();
protected DefaultChannelPipeline newChannelPipeline() {
return new DefaultChannelPipeline(this);
发现,其实是使用了DefaultChannelPipeline。进入该类构造方法,返现实例化的时候创建了,HeadContext 和 TailContext来作为pipeline的头和尾
protected DefaultChannelPipeline(Channel channel) {
this.channel = ObjectUtil.checkNotNull(channel, "channel");
succeededFuture = new SucceededChannelFuture(channel, null);
voidPromise = new VoidChannelPromise(channel, true);
tail = new TailContext(this);
head = new HeadContext(this);
head.next = tail;
tail.prev = head;
进入HeadContext#bind()方法,发现其实是调用了unsafe的方法
@Override
public void bind(
ChannelHandlerContext ctx, SocketAddress localAddress, ChannelPromise promise)
throws Exception {
unsafe.bind(localAddress, promise);
经过分析该成员变量是与pipeline一样在AbstractChannel的构造方法中被实例化。其实就是NioServerSocketChannel的实例化过程。其中就进行了成员变量AbstractNioChannel.readInterestOp初始化的,其值就是SelectionKey.OP_ACCEPT事件
public NioServerSocketChannel(ServerSocketChannel channel) {
//初始化过程传入了Selecor事件:accept
super(null, channel, SelectionKey.OP_ACCEPT);
config = new NioServerSocketChannelConfig(this, javaChannel().socket());
protected AbstractNioChannel(Channel parent, SelectableChannel ch, int readInterestOp) {
super(parent);
this.ch = ch;
//初始化事件成员变量
this.readInterestOp = readInterestOp;
try {
ch.configureBlocking(false);
} catch (IOException e) {
try {
ch.close();
} catch (IOException e2) {
if (logger.isWarnEnabled()) {
logger.warn(
"Failed to close a partially initialized socket.", e2);
throw new ChannelException("Failed to enter non-blocking mode.", e);
