mongodb.MongoException$Network: can't call something 更新
spring 和mongodb集成的话,设置如下:
<?xml version="1.0" encoding="UTF-8"?>
<beans xmlns="http://www.springframework.org/schema/beans"
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:context="http://www.springframework.org/schema/context"
xmlns:mongo="http://www.springframework.org/schema/data/mongo"
xsi:schemaLocation="http://www.springframework.org/schema/context
http://www.springframework.org/s ... ing-context-3.0.xsd
http://www.springframework.org/s ... pring-mongo-1.0.xsd
http://www.springframework.org/schema/beans/spring-beans-3.0.xsd">
<context:property-placeholder location="classpath*:META-INF/mongodb/mongodb.properties"/>
<!-- 定义mongo对象,对应的是mongodb官方jar包中的Mongo,replica-set设置集群副本的ip地址和端口 -->
<mongo:mongo id="mongo" replica-set="localhost:27017">
<!-- 一些连接属性的设置 -->
<mongo ptions
connections-per-host="${mongo.connectionsPerHost}"
threads-allowed-to-block-for-connection-multiplier="${mongo.threadsAllowedToBlockForConnectionMultiplier}"
connect-timeout="${mongo.connectTimeout}"
max-wait-time="${mongo.maxWaitTime}"
auto-connect-retry="${mongo.autoConnectRetry}"
socket-keep-alive="${mongo.socketKeepAlive}"
socket-timeout="${mongo.socketTimeout}"
slave-ok="${mongo.slaveOk}"
write-number="1"
write-timeout="0"
write-fsync="true"/>
</mongo:mongo>
<!-- mongo的工厂,通过它来取得mongo实例,dbname为mongodb的数据库名,没有的话会自动创建 -->
<mongo:db-factory dbname="test" mongo-ref="mongo"/>
<!-- mongodb的主要操作对象,所有对mongodb的增删改查的操作都是通过它完成 -->
<bean id="mongoTemplate" class="org.springframework.data.mongodb.core.MongoTemplate">
<constructor-arg name="mongoDbFactory" ref="mongoDbFactory"/>
</bean>
<!-- 映射转换器,扫描back-package目录下的文件,根据注释,把它们作为mongodb的一个collection的映射 -->
<mongo:mapping-converter base-package="com.xxx.xxx.domain" />
<!-- mongodb bean的仓库目录,会自动扫描扩展了MongoRepository接口的接口进行注入 -->
<mongo:repositories base-package="com.xxx.xxx.persist.mongodb"/>
<!-- To translate any MongoExceptions thrown in @Repository annotated classes -->
<context:annotation-config />
</beans> |
