java处理数据文本时间小函数积累(3)
多个字符分割 比如我想把有,或者有分号的都分开
        Pattern pattern = Pattern.compile("[,;]+");
            String[] strs = pattern.split("Java Hello World  Java,Hello,,World;Sun");
            for (int i=0;i<strs.length;i++) {
                System.out.println(strs[i]);
取文本中多个数值的较大值
    protected String formatMaxNumber(String value) {
            List<Float> fl = new ArrayList<Float>();
            if (value != null) {
                Matcher valueMatcher = intPattern.matcher(value);
                while (valueMatcher.find()) {
                    String strRjl = valueMatcher.group();
                    float rst = Float.valueOf(strRjl);
                    fl.add(rst);
                if (fl.size() == 1) {
                    return fl.get(0).toString();
                } else if (fl.size() == 2) {
                    if (fl.get(0) > fl.get(1)) {
                    } else {
                        return fl.get(1).toString();
            return null;
