指定maven的目录路径(1)
指定maven的目录路径(1)
规范的maven项目路径为
    myproject/
    |-- pom.xml
    `-- src
        |-- main
        |   |-- java
        |   |   `-- com
        |   |       `-- mycompany
        |   |-- resources
        |   `-- webapp
        |       |-- WEB-INF
        |       |   `-- web.xml
        |       `-- index.jsp
        `-- test
            |-- java
            |   `-- com
            |       `-- mycompany
            `-- resources
如果我们的项目是非规范的maven项目,或者说我们想对maven项目的目录进行指定修改
可以用如下pom.xml
sourceDirectory目录涉及到 class中java的发布
warSourceDirectory涉及到 jsp的发布
如果没设置对,发布后的项目中就会有jsp或者.class文件缺失
     <build>
            <sourceDirectory>src/</sourceDirectory>
            <resources>
                <resource>
                    <directory>src</directory>
                    <excludes>
                        <exclude>**/*.java</exclude>
                    </excludes>
                </resource>
                <resource>
                    <directory>resource</directory>
                    <excludes>
                    </excludes>
                </resource>
            </resources>
            <plugins>
                <plugin>
                    <groupId>org.apache.maven.plugins</groupId>
                    <artifactId>maven-war-plugin</artifactId>
                    <version>2.5</version>
                    <configuration>
                        <webXml>./WebRoot/WEB-INF/web.xml</webXml>
                        <warSourceDirectory>WebRoot</warSourceDirectory>
                    </configuration>
                </plugin>
                <plugin>
                    <artifactId>maven-surefire-plugin</artifactId>
                    <version>2.17</version>
                </plugin>
                <plugin>
                    <groupId>org.codehaus.mojo</groupId>
                    <artifactId>findbugs-maven-plugin</artifactId>
                    <version>2.5.5</version>
                </plugin>
                <plugin>
                    <artifactId>maven-checkstyle-plugin</artifactId>
                    <version>2.13</version>
                    <configuration>
                        <configLocation>resource/checkstyle_checks.xml</configLocation>
                    </configuration>
                </plugin>
                <plugin>
                    <artifactId>maven-pmd-plugin</artifactId>
                    <version>3.2</version>
                </plugin>
            </plugins>
        </build>
