httpclient常用基本抓取类(7)
     * 新ip第一次访问时要先通过安全验证,这时只能得到首页的内容,所以在post前线验证一次 <功能详细描述> [参数说明]
     * @return void [返回类型说明]
     * @exception throws [违例类型] [违例说明]
     * @see [类、类#方法、类#成员]
    private Boolean postByCompanyProxyBoolean(String url, String parm,
            String encode) throws ClientProtocolException, IOException {
        int count = 10;
        String result = "";
        String urlString = url;
        String proxy = "";
        HttpHost proxyHost = null;
        boolean newProxy = false;
        int oldProxyUsecount = 0;
        for (int i = 0; i <= count; i++) {
            try {
                if (newProxy || oldProxyUsecount > 2 || ip.equals("")) {
                    String[] proxys = null;
                    try {
                        while (proxy.equals("") || !proxy.contains(":")) {
                            System.out.println("ip为空,正在提取");
                            proxy = doGet(ipUrl, "gbk");
                        proxys = proxy.replaceAll("\"|//|/|\r\n| | ", "")
                                .split(":");
                    } catch (Exception e) {
                        proxys = proxy.replaceAll("\"|//|/|\r\n| ", "").split(
                    ip = proxys[0];
                    port = Integer.parseInt(proxys[1]);
                    proxyHost = new HttpHost(ip, port, null);
                System.out.println("正在使用代理" + ip + ":" + port);
                HttpPost httpRequst = new HttpPost(url);// 创建HttpPost对象
                StringEntity entity = new StringEntity(parm);
                entity.setContentType("application/x-www-form-urlencoded");
                httpRequst.setEntity(entity);
                httpRequst.getParams().setParameter(
                        CoreProtocolPNames.HTTP_CONTENT_CHARSET, encode);
                httpPostClient.getParams().setParameter(
                        CoreConnectionPNames.CONNECTION_TIMEOUT, 10000);// 连接时间20s
                        CoreConnectionPNames.SO_TIMEOUT, 8000);// 数据传输时间60s
                        ConnRouteParams.DEFAULT_PROXY, proxyHost);
                HttpResponse httpResponse = httpPostClient.execute(httpRequst);// 其中HttpGet是HttpUriRequst的子类
                if (httpResponse.getStatusLine().getStatusCode() == 200) {
                    HttpEntity httpEntity = httpResponse.getEntity();
                    if (httpEntity.getContentEncoding() != null) {
                        if ("gzip".equalsIgnoreCase(httpEntity
                                .getContentEncoding().getValue())) {
                            httpEntity = new GzipDecompressingEntity(httpEntity);
                        } else if ("deflate".equalsIgnoreCase(httpEntity
                            httpEntity = new DeflateDecompressingEntity(
                                    httpEntity);
                    result = enCodetoString(httpEntity, encode);// 取出应答字符串
                    // System.out.println(result);
                    if (resultTest(result)) {
                        return true;
                    } else if (result.contains("function JumpSelf")
                            && result.contains("WebShieldSessionVerify")) {
                        int indexs = result.indexOf("&WebShieldSessionVerify");
                        int indexe = result.indexOf("\";}</script>");
                        String verify = result.substring(indexs, indexe);
                        urlString = urlString + verify;
                        if (urlString.contains("tabid=26")
                                && !urlString.contains("landchina")) {
                            urlString = "http://www.landchina.com" + urlString;
                            result = getByHttpClient(urlString, encode,
                                    httpPostClient);
                                System.out.println(ip + "公司代理成功抓取" + url);
                                return true;
                            newProxy = false;
                        } else if (urlString.contains("tabid=26")
                                && urlString.contains("landchina")) {
                                    httpPostClient);
                                return true;
                            newProxy = false;
                        newProxy = false;
                            && !result.contains("WebShieldSessionVerify")) {
                        urlString = url;
                        newProxy = false;
                } else if (httpResponse.getStatusLine().getStatusCode() == 302) {
                    System.out.println("重定向了");
                    Header header = httpResponse.getFirstHeader("location");
                    if (header != null) {
                        urlString = header.getValue();
                        System.out.println(urlString);
                                    httpPostClient);
                                return true;
                            newProxy = false;
                                    httpPostClient);
                                return true;
                            newProxy = false;
                        newProxy = false;
                } else {
                    httpRequst.abort();
            } catch (ClientProtocolException e) {
                newProxy = true;
                System.out.println(ip + "代理ip拒绝了");
            } catch (IOException e) {
                oldProxyUsecount++;
                System.out.println(ip + "代理读取超时");
        return false;
