可用的ss-mongo框架的pom.xml及相关的web.xml(1)
pom.xml
简洁版spring+struts
    <project xmlns="http://maven.apache.org/POM/4.0.0" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
        xsi:schemaLocation="http://maven.apache.org/POM/4.0.0 http://maven.apache.org/xsd/maven-4.0.0.xsd">
        <modelVersion>4.0.0</modelVersion>
        <groupId>23mofang</groupId>
        <artifactId>23mofang</artifactId>
        <version>0.0.1-SNAPSHOT</version>
        <packaging>war</packaging>
        <name />
        <description />
        <properties>
            <project.build.sourceEncoding>UTF-8</project.build.sourceEncoding>
            <struts.version>2.3.20</struts.version>
            <httpcomponents.version>4.2.5</httpcomponents.version>
            <spring.version>3.2.5.RELEASE</spring.version>
        </properties>
        <dependencies>
            <dependency>
                <groupId>org.apache.struts</groupId>
                <artifactId>struts2-core</artifactId>
                <version>${struts.version}</version>
            </dependency>
            <dependency>
                <artifactId>struts2-json-plugin</artifactId>
            </dependency>
            <dependency>
                <artifactId>struts2-spring-plugin</artifactId>
            </dependency>
            <dependency>
                <groupId>org.apache.httpcomponents</groupId>
                <artifactId>httpclient</artifactId>
                <version>${httpcomponents.version}</version>
            </dependency>
            <dependency>
                <artifactId>httpclient-cache</artifactId>
            </dependency>
            <dependency>
                <artifactId>httpcore</artifactId>
            </dependency>
            <dependency>
                <groupId>javax.servlet</groupId>
                <artifactId>servlet-api</artifactId>
                <version>2.3</version>
                <scope>provided</scope>
            </dependency>
            <dependency>
                <groupId>org.springframework</groupId>
                <artifactId>spring-web</artifactId>
                <version>${spring.version}</version>
            </dependency>
            <dependency>
                <artifactId>spring-orm</artifactId>
            </dependency>
            <dependency>
                <artifactId>spring-context-support</artifactId>
            </dependency>
            <dependency>
                <artifactId>spring-aspects</artifactId>
            </dependency>
            <dependency>
                <artifactId>spring-core</artifactId>
            </dependency>
            <dependency>
                <artifactId>spring-beans</artifactId>
            </dependency>
            <dependency>
                <artifactId>spring-context</artifactId>
            </dependency>
            <dependency>
                <groupId>org.springframework.data</groupId>
                <artifactId>spring-data-mongodb</artifactId>
                <version>1.5.5.RELEASE</version>
            </dependency>
            <dependency>
                <groupId>net.sf.ehcache</groupId>
                <artifactId>ehcache</artifactId>
                <version>2.8.4</version>
            </dependency>
            <dependency>
                <groupId>com.belerweb</groupId>
                <artifactId>pinyin4j</artifactId>
                <version>2.5.0</version>
            </dependency>
            <dependency>
                <groupId>log4j</groupId>
                <artifactId>log4j</artifactId>
                <version>1.2.17</version>
            </dependency>
            <dependency>
                <groupId>org.codehaus.jackson</groupId>
                <artifactId>jackson-mapper-asl</artifactId>
                <version>1.9.13</version>
            </dependency>
            <dependency>
                <groupId>commons-httpclient</groupId>
                <artifactId>commons-httpclient</artifactId>
                <version>3.1</version>
            </dependency>
            <dependency>
                <groupId>org.jsoup</groupId>
                <artifactId>jsoup</artifactId>
                <version>1.7.2</version>
            </dependency>
            <dependency>
                <groupId>org.quartz-scheduler</groupId>
                <artifactId>quartz</artifactId>
                <version>2.2.1</version>
            </dependency>
            <dependency>
                <artifactId>quartz-jobs</artifactId>
            </dependency>
            <dependency>
                <groupId>commons-logging</groupId>
                <artifactId>commons-logging</artifactId>
                <version>1.1.1</version>
            </dependency>
        </dependencies>
        <build>
            <plugins>
                <plugin>
                    <artifactId>maven-war-plugin</artifactId>
                </plugin>
                <plugin>
                    <artifactId>maven-compiler-plugin</artifactId>
                    <configuration>
                        <source>1.6</source>
                        <target>1.6</target>
                    </configuration>
                </plugin>
                <plugin>
                    <groupId>org.codehaus.mojo</groupId>
                    <artifactId>findbugs-maven-plugin</artifactId>
                    <version>2.5.5</version>
                </plugin>
                <plugin>
                    <groupId>org.apache.tomcat.maven</groupId>
                    <artifactId>tomcat7-maven-plugin</artifactId>
                    <version>2.0</version>
                </plugin>
                <plugin>
                    <groupId>org.apache.maven.plugins</groupId>
                    <artifactId>maven-checkstyle-plugin</artifactId>
                    <version>2.13</version>
                    <configuration>
                        <configLocation>resource/checkstyle_checks.xml</configLocation>
                    </configuration>
                </plugin>
            </plugins>
            <resources>
                <resource>
                    <directory>resource</directory>
                </resource>
            </resources>
        </build>
    </project>
