可用的ss-mongo框架的pom.xml及相关的web.xml(2)
完整版
    <project xmlns="http://maven.apache.org/POM/4.0.0" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
        xsi:schemaLocation="http://maven.apache.org/POM/4.0.0 http://maven.apache.org/xsd/maven-4.0.0.xsd">
        <modelVersion>4.0.0</modelVersion>
        <groupId>com.reallyinfo</groupId>
        <artifactId>buildingProject</artifactId>
        <version>1.0.0-SNAPSHOT</version>
        <properties>
            <project.build.sourceEncoding>UTF-8</project.build.sourceEncoding>
        </properties>
        <build>
            <plugins>
                <plugin>
                    <groupId>org.apache.maven.plugins</groupId>
                    <artifactId>maven-war-plugin</artifactId>
                    <version>2.5</version>
                </plugin>
                <plugin>
                    <artifactId>maven-surefire-plugin</artifactId>
                    <version>2.17</version>
                </plugin>
                <plugin>
                    <groupId>org.codehaus.mojo</groupId>
                    <artifactId>findbugs-maven-plugin</artifactId>
                    <version>2.5.5</version>
                </plugin>
                <plugin>
                    <artifactId>maven-checkstyle-plugin</artifactId>
                    <version>2.13</version>
                    <configuration>
                        <configLocation>resource/checkstyle_checks.xml</configLocation>
                    </configuration>
                </plugin>
                <plugin>
                    <artifactId>maven-pmd-plugin</artifactId>
                    <version>3.2</version>
                </plugin>
            </plugins>
        </build>
        <dependencies>
            <dependency>
                <groupId>jdk.tools</groupId>
                <artifactId>jdk.tools</artifactId>
                <version>1.6</version>
                <scope>system</scope>
                <systemPath>${JAVA_HOME}/lib/tools.jar</systemPath>
            </dependency>
            <dependency>
                <groupId>org.apache.httpcomponents</groupId>
                <artifactId>httpcore</artifactId>
                <version>4.2.4</version>
            </dependency>
            <dependency>
                <groupId>junit</groupId>
                <artifactId>junit</artifactId>
                <version>4.11</version>
                <scope>test</scope>
            </dependency>
            <dependency>
                <groupId>org.apache.mrunit</groupId>
                <artifactId>mrunit</artifactId>
                <version>1.1.0</version>
                <classifier>hadoop2</classifier>
            </dependency>
            <dependency>
                <groupId>org.apache.hadoop</groupId>
                <artifactId>hadoop-common</artifactId>
                <version>2.4.1</version>
                <exclusions>
                    <exclusion>
                        <artifactId>servlet-api</artifactId>
                        <groupId>javax.servlet</groupId>
                    </exclusion>
                    <exclusion>
                        <artifactId>jsp-api</artifactId>
                        <groupId>javax.servlet.jsp</groupId>
                    </exclusion>
                </exclusions>
            </dependency>
            <dependency>
                <artifactId>hadoop-hdfs</artifactId>
                <exclusions>
                    <exclusion>
                    </exclusion>
                    <exclusion>
                    </exclusion>
                </exclusions>
            </dependency>
            <dependency>
                <groupId>org.mongodb</groupId>
                <artifactId>mongo-java-driver</artifactId>
                <version>2.12.3</version>
            </dependency>
            <dependency>
                <artifactId>mongo-hadoop-core</artifactId>
                <version>1.3.0</version>
                <exclusions>
                    <exclusion>
                    </exclusion>
                    <exclusion>
                    </exclusion>
                </exclusions>
            </dependency>
            <dependency>
                <artifactId>mongo-hadoop-pig</artifactId>
                <exclusions>
                    <exclusion>
                        <artifactId>jsp-api-2.1</artifactId>
                        <groupId>org.mortbay.jetty</groupId>
                    </exclusion>
                    <exclusion>
                        <artifactId>jsp-2.1</artifactId>
                    </exclusion>
                </exclusions>
            </dependency>
            <dependency>
                <artifactId>mongo-hadoop-hive</artifactId>
                <exclusions>
                    <exclusion>
                    </exclusion>
                </exclusions>
            </dependency>
            <dependency>
                <groupId>org.apache.poi</groupId>
                <artifactId>poi</artifactId>
                <version>3.9</version>
            </dependency>
            <dependency>
                <groupId>net.sourceforge.jexcelapi</groupId>
                <artifactId>jxl</artifactId>
                <version>2.5.7</version>
            </dependency>
            <dependency>
                <groupId>org.json</groupId>
                <artifactId>json</artifactId>
                <version>20090211</version>
            </dependency>
