centos安装php php-fpm 以及 配置nginx
下载php源码包
安装php
tar -xvf php-5.5.13.tar.bz2
cd php-5.5.13
./configure --prefix=/usr/local/php --with-config-file-path=/etc --enable-inline-optimization --disable-debug --disable-rpath --enable-shared --enable-opcache --enable-fpm --with-fpm-user=www --with-fpm-group=www --with-mysql=mysqlnd --with-mysqli=mysqlnd --with-pdo-mysql=mysqlnd --with-gettext --enable-mbstring --with-iconv --with-mcrypt --with-mhash --with-openssl --enable-bcmath --enable-soap --with-libxml-dir --enable-pcntl --enable-shmop --enable-sysvmsg --enable-sysvsem --enable-sysvshm --enable-sockets --with-curl --with-zlib --enable-zip --with-bz2 --with-readline --without-sqlite3 --without-pdo-sqlite --with-pear
可能出现的错误
出现错误: congigure error: xml2-config not found
解决办法:
1.执行命令:
sudo yum install libxml2-devel
2.查看是否成功:
find / -name "xml2-config"
作者:张小凡vip
来源:CSDN
原文:https://blog.csdn.net/zzq900503/article/details/45499967
版权声明:本文为博主原创文章,转载请附上博文链接!
出现错误: congigure error: Cannot find OpenSSL's <evp.h>
解决办法:
yum install openssl openssl-devel
ln -s /usr/lib64/libssl.so /usr/lib/
出现错误: configure: error: Please reinstall the BZip2 distribution
解决办法:
yum install bzip2 bzip2-devel
出现错误: configure: error: Please reinstall the libcurl distribution -easy.h should be in <curl-dir>/include/curl/
解决办法:
yum -y install curl-devel
出现错误:configure: error: mcrypt.h not found. Please reinstall libmcrypt.
解决办法:
sudo yum install libmcrypt libmcrypt-devel mcrypt mhash
出现错误:configure: error: Please reinstall readline - I cannot find readline.h
解决办法:
sudo yum install readline-devel
编译
make
make install
可能出现的错误
编译PHP5.5 make 时出现错误
make: *** [ext/fileinfo/libmagic/apprentice.lo] Error 1
解决办法:
这是由于内存小于1G所导致.Disable fileinfo support 禁用 fileinfo
在./configure加上选项:
--disable-fileinfo
配置环境变量
添加 PHP 命令到环境变量
vim /etc/profile
在末尾加入
PATH=$PATH:/usr/local/php/bin
export PATH
要使改动立即生效执行
. /etc/profile 或 source /etc/profile
查看环境变量
echo $PATH
查看php版本
php -v
PHP 5.5.13 (cli) (built: Jun 20 2014 11:11:26)
Copyright (c) 1997-2014 The PHP Group
Zend Engine v2.5.0, Copyright (c) 1998-2014 Zend Technologies
配置启动php-fpm
cd /usr/local/php/etc
cp php-fpm.conf.default php-fpm.conf
启动php-fpm
sudo /usr/local/php/sbin/php-fpm
配置nginx
修改nginx的配置文件(/etc/nginx/conf.d/default.conf)
location / {
root web根目录;//在服务器中的目录
index index.html index.htm index.php;
location ~ \.php$ {
root html;
fastcgi_pass 127.0.0.1:9000; //这个iP和端口对应php-fpm设置的端口
fastcgi_index index.php;
fastcgi_param SCRIPT_FILENAME web根目录$fastcgi_script_name;
include fastcgi_params;
检查nginx
[root@server nginx]# ./sbin/nginx -t //检测配置文件是否正常
nginx: the configuration file /usr/local/nginx/conf/nginx.conf syntax is ok
nginx: configuration file /usr/local/nginx/conf/nginx.conf test is successful
则 已经配置正确
重启nginx
/etc/init.d/nginx restart
在web根目录下创建index.php
<?php echo phpinfo(); ?>
在浏览器中输入http://ip/index.php查看成功即可。
//注:根据自己的配置修改web根目录即可,如我的为/usr/share/nginx/html。
如果启动php-fpm出现错误: can not get uid for www,修改php-fpm.conf中user为nginx group为nginx |
