jsp接收action的值的方法总结(2)
完整代码例子
TestAction.java
    package action;
    import java.util.Map;
    import javax.servlet.ServletContext;
    import javax.servlet.http.HttpServletRequest;
    import javax.servlet.http.HttpSession;
    import org.apache.struts2.ServletActionContext;
    import com.opensymphony.xwork2.ActionContext;
    import com.opensymphony.xwork2.ActionSupport;
    public class TestAction extends ActionSupport{
         * action调用样例
        private static final long serialVersionUID = -3544701251834366894L;
        private String id;
        private String name;
        public String getId() {
            return id;
        public void setId(String id) {
            this.id = id;
        public String getName() {
            return name;
        public void setName(String name) {
            this.name = name;
        public String execute(){
            System.out.println("testAction runing!");
            name="我是action中通过get传递的值";
    /*         HttpServletRequest request = ServletActionContext.getRequest ();
             request.setAttribute("SR","我是ServletActionContext作容器Request传值");
             ServletContext application = ServletActionContext.getServletContext ();
             application.setAttribute("SA","我是ServletActionContext作容器application传值");
             HttpSession session = ServletActionContext.getRequest ().getSession();
             session.setAttribute("SS","我是ServletActionContext作容器session传值");*/
              ActionContext context= ActionContext.getContext();
              Map request = (Map)context.get("request");
              request.put("AR","我是ActionContext作容器Request传值");
              Map application = (Map)context.getApplication();
              application.put("AA","我是ActionContext作容器application传值");
              Map session = (Map)context.getSession();
              session.put("AS","我是ActionContext作容器session传值");
            return SUCCESS;
index.jsp
    <%@ page language="java" import="java.util.*" pageEncoding="utf-8"%>
    String path = request.getContextPath();
    String basePath = request.getScheme()+"://"+request.getServerName()+":"+request.getServerPort()+path+"/";
    <%@ taglib uri="/struts-tags" prefix="s"%>
    <!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
    <html>
      <head>
        <base href="<%=basePath%>">
        <title>My JSP 'index.jsp' starting page</title>
      </head>
      <body>
      <s:property value="name"/><BR/>
    <s:property value="#request.SR"/><BR/>
    <s:property value="#application.SA"/><BR/>
    <s:property value="#session.SS"/><BR/>
    <s:property value="#request.AR"/><BR/>
    <s:property value="#application.AA"/><BR/>
    <s:property value="#session.AS"/>
      </body>
    </html>
spring  action.xml
    <?xml version="1.0" encoding="utf-8"?>
    <!-- 指定Spring配置文件的Schema信息 -->
    <beans xmlns="http://www.springframework.org/schema/beans"
        xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:aop="http://www.springframework.org/schema/aop"
        xmlns:p="http://www.springframework.org/schema/p" xmlns:tx="http://www.springframework.org/schema/tx"
        xmlns:mongo="http://www.springframework.org/schema/data/mongo"
        xmlns:context="http://www.springframework.org/schema/context"
        xsi:schemaLocation="http://www.springframework.org/schema/beans
        http://www.springframework.org/schema/beans/spring-beans-3.1.xsd
        http://www.springframework.org/schema/tx/spring-tx-3.0.xsd
        http://www.springframework.org/s ... ing-context-3.1.xsd
        http://www.springframework.org/schema/aop/spring-aop-3.1.xsd">
         <bean id="testAction" class="action.TestAction">
        </bean>
       <bean id="login" class="action.LoginAction">
        </bean>
    </beans>
struts action.xml
    <!DOCTYPE struts PUBLIC
        "-//Apache Software Foundation//DTD Struts Configuration 2.1.7//EN"
        "http://struts.apache.org/dtds/struts-2.1.7.dtd">
    <struts>
        <package name="getIp" extends="json-default" namespace="/getIp">
            <action name="testJson" class="testAction">
                <result type="json"></result>
            </action>
            <action name="testJsp"  class="testAction">
                <result name="success">/index.jsp</result>
            </action>
            <action name="login"  class="login">
            </action>
        </package>
    </struts>
