java导出文件弹出下载框让用户选择路径(1)
其中关键的设置是
    <struts>
       <package name="struts2" extends="struts-default">
           <action name="FileDownload" class="com.struts2.filedownload.FileDownload">
               <result name="success" type="stream">
                   <param name="contentType">text/plain</param>
                   <param name="contentDisposition">attachment;fileName="${fileName}"</param>
                   <param name="inputName">downloadFile</param>
                   <param name="bufferSize">1024</param>
               </result>
           </action>
       </package>
    </struts>
web-SpringMvc等非struts框架中弹出
在response中设置头
    response.addHeader("Content-Disposition", "attachment;filename="+ new String(filename.getBytes()));
               OutputStream os= new BufferedOutputStream(response.getOutputStream());
               response.setContentType("application/vnd.ms-excel;charset=gb2312");
               os.write(buffer);
               os.flush();
               os.close();
例如:
jsp页面 使用js    提交 post  form
        $(document).ready(function() {
            var $searchForm = $('#search_form').on('submit',function(){
                $dt.DataTable().searchEx( {} ).draw();
                return false;
            }).on('click', 'button.export', function(){
            var searchData={};
            searchData.search=$('#search_form').formGet();
              console.log(searchData);
               post('/order/list/export',searchData);
          function post(URL, PARAMS) {
            var temp = document.createElement("form");
            temp.action = URL;
            temp.method = "post";
            temp.style.display = "none";
            for (var x in PARAMS.search) {
               var opt = document.createElement("textarea");
               if(x=="id"||x=="expressNumber"||x=="payStatus"){
                 opt.name = x;
                 opt.value = PARAMS.search[x];
                 temp.appendChild(opt);
            document.body.appendChild(temp);
            temp.submit();
后端接受参数后查询出数据,把生成的excel写入excel,返回文件流
        @RequestMapping("/list/export")
        public Object export(@RequestParam String id,@RequestParam  String expressNumber,@RequestParam String payStatus,HttpServletResponse response) {
            PagerRequest<Map> req=new PagerRequest<Map>();
            req.setLength(0);
            req.setOffset(0);
            HashMap<String, String> search=new HashMap<String, String>();
            search.put("id", id);
            search.put("expressNumber", expressNumber);
            search.put("payStatus", payStatus);
            req.setSearch(search);
            List<Order> orders = new ArrayList<Order>();
            if (req.getSearch() == null||req.getSearch().size()==0) {
                orders = (List<Order>) orderRepository.findAll();
            } else {
                Page<Order> page = orderRepository.listWithSearch(new PageRequest(
                        0,(int) orderRepository.count()), req
                        .getSearch());
                orders = page.getContent();
            if (productService.exportOrders(orders,response)) {
                return null;
            return null;
