java进阶(二)------java编程规范---myeclipse格式化设置(3)
<setting id="org.eclipse.jdt.core.formatter.insert_space_before_opening_angle_bracket_in_type_parameters" value="do not insert"/>
    <setting id="org.eclipse.jdt.core.formatter.comment.clear_blank_lines_in_block_comment" value="false"/>
    <setting id="org.eclipse.jdt.core.formatter.insert_new_line_in_empty_type_declaration" value="insert"/>
    <setting id="org.eclipse.jdt.core.formatter.lineSplit" value="100"/>
    <setting id="org.eclipse.jdt.core.formatter.insert_space_before_opening_paren_in_if" value="insert"/>
    <setting id="org.eclipse.jdt.core.formatter.insert_space_between_brackets_in_array_type_reference" value="do not insert"/>
    <setting id="org.eclipse.jdt.core.formatter.insert_space_after_opening_paren_in_parenthesized_expression" value="do not insert"/>
    <setting id="org.eclipse.jdt.core.formatter.insert_space_before_comma_in_explicitconstructorcall_arguments" value="do not insert"/>
    <setting id="org.eclipse.jdt.core.formatter.insert_space_before_opening_brace_in_constructor_declaration" value="insert"/>
    <setting id="org.eclipse.jdt.core.formatter.blank_lines_before_first_class_body_declaration" value="0"/>
    <setting id="org.eclipse.jdt.core.formatter.insert_new_line_after_annotation_on_method" value="insert"/>
    <setting id="org.eclipse.jdt.core.formatter.indentation.size" value="4"/>
    <setting id="org.eclipse.jdt.core.formatter.insert_space_between_empty_parens_in_method_declaration" value="do not insert"/>
    <setting id="org.eclipse.jdt.core.formatter.enabling_tag" value="@formattern"/>
    <setting id="org.eclipse.jdt.core.formatter.insert_space_before_opening_paren_in_enum_constant" value="do not insert"/>
    <setting id="org.eclipse.jdt.core.formatter.alignment_for_superclass_in_type_declaration" value="16"/>
    <setting id="org.eclipse.jdt.core.formatter.alignment_for_assignment" value="16"/>
    <setting id="org.eclipse.jdt.core.compiler.problem.assertIdentifier" value="error"/>
    <setting id="org.eclipse.jdt.core.formatter.tabulation.char" value="space"/>
    <setting id="org.eclipse.jdt.core.formatter.insert_space_after_comma_in_constructor_declaration_parameters" value="insert"/>
    <setting id="org.eclipse.jdt.core.formatter.insert_space_after_semicolon_in_try_resources" value="insert"/>
    <setting id="org.eclipse.jdt.core.formatter.insert_space_before_prefix_operator" value="do not insert"/>
    <setting id="org.eclipse.jdt.core.formatter.indent_statements_compare_to_body" value="true"/>
    <setting id="org.eclipse.jdt.core.formatter.blank_lines_before_method" value="1"/>
    <setting id="org.eclipse.jdt.core.formatter.wrap_outer_expressions_when_nested" value="true"/>
    <setting id="org.eclipse.jdt.core.formatter.format_guardian_clause_on_one_line" value="false"/>
    <setting id="org.eclipse.jdt.core.formatter.insert_space_before_colon_in_for" value="insert"/>
    <setting id="org.eclipse.jdt.core.formatter.insert_space_before_closing_paren_in_cast" value="do not insert"/>
    <setting id="org.eclipse.jdt.core.formatter.alignment_for_parameters_in_constructor_declaration" value="16"/>
    <setting id="org.eclipse.jdt.core.formatter.insert_space_after_colon_in_labeled_statement" value="insert"/>
    <setting id="org.eclipse.jdt.core.formatter.brace_position_for_annotation_type_declaration" value="end_of_line"/>
    <setting id="org.eclipse.jdt.core.formatter.insert_new_line_in_empty_method_body" value="do not insert"/>
    <setting id="org.eclipse.jdt.core.formatter.alignment_for_method_declaration" value="0"/>
    <setting id="org.eclipse.jdt.core.formatter.insert_space_before_closing_paren_in_method_invocation" value="do not insert"/>
    <setting id="org.eclipse.jdt.core.formatter.insert_space_before_closing_paren_in_try" value="do not insert"/>
    <setting id="org.eclipse.jdt.core.formatter.insert_space_after_opening_bracket_in_array_allocation_expression" value="do not insert"/>
    <setting id="org.eclipse.jdt.core.formatter.insert_space_before_opening_brace_in_enum_constant" value="insert"/>
    <setting id="org.eclipse.jdt.core.formatter.insert_space_before_comma_in_annotation" value="do not insert"/>
    <setting id="org.eclipse.jdt.core.formatter.insert_space_after_at_in_annotation_type_declaration" value="do not insert"/>
    <setting id="org.eclipse.jdt.core.formatter.insert_space_before_comma_in_method_declaration_throws" value="do not insert"/>
    <setting id="org.eclipse.jdt.core.formatter.insert_space_before_closing_paren_in_if" value="do not insert"/>
    <setting id="org.eclipse.jdt.core.formatter.brace_position_for_switch" value="end_of_line"/>
    <setting id="org.eclipse.jdt.core.formatter.insert_space_after_comma_in_method_declaration_throws" value="insert"/>
    <setting id="org.eclipse.jdt.core.formatter.insert_space_before_parenthesized_expression_in_return" value="insert"/>
    <setting id="org.eclipse.jdt.core.formatter.insert_space_before_opening_paren_in_annotation" value="do not insert"/>
    <setting id="org.eclipse.jdt.core.formatter.insert_space_after_question_in_conditional" value="insert"/>
    <setting id="org.eclipse.jdt.core.formatter.insert_space_after_question_in_wildcard" value="do not insert"/>
    <setting id="org.eclipse.jdt.core.formatter.insert_space_after_opening_paren_in_try" value="do not insert"/>
    <setting id="org.eclipse.jdt.core.formatter.insert_space_before_closing_bracket_in_array_allocation_expression" value="do not insert"/>
    <setting id="org.eclipse.jdt.core.formatter.comment.preserve_white_space_between_code_and_line_comments" value="false"/>
    <setting id="org.eclipse.jdt.core.formatter.insert_space_before_parenthesized_expression_in_throw" value="insert"/>
    <setting id="org.eclipse.jdt.core.formatter.insert_space_before_comma_in_type_arguments" value="do not insert"/>
    <setting id="org.eclipse.jdt.core.compiler.problem.enumIdentifier" value="error"/>
    <setting id="org.eclipse.jdt.core.formatter.indent_switchstatements_compare_to_switch" value="true"/>
    <setting id="org.eclipse.jdt.core.formatter.insert_space_before_ellipsis" value="do not insert"/>
    <setting id="org.eclipse.jdt.core.formatter.brace_position_for_block" value="end_of_line"/>
    <setting id="org.eclipse.jdt.core.formatter.insert_space_before_comma_in_for_inits" value="do not insert"/>
    <setting id="org.eclipse.jdt.core.formatter.brace_position_for_method_declaration" value="end_of_line"/>
    <setting id="org.eclipse.jdt.core.formatter.compact_else_if" value="true"/>
    <setting id="org.eclipse.jdt.core.formatter.wrap_before_or_operator_multicatch" value="true"/>
    <setting id="org.eclipse.jdt.core.formatter.insert_space_before_comma_in_array_initializer" value="do not insert"/>
    <setting id="org.eclipse.jdt.core.formatter.insert_space_after_comma_in_for_increments" value="insert"/>
    <setting id="org.eclipse.jdt.core.formatter.format_line_comment_starting_on_first_column" value="true"/>
    <setting id="org.eclipse.jdt.core.formatter.insert_space_before_closing_bracket_in_array_reference" value="do not insert"/>
    <setting id="org.eclipse.jdt.core.formatter.insert_new_line_after_annotation_on_field" value="insert"/>
    <setting id="org.eclipse.jdt.core.formatter.brace_position_for_enum_constant" value="end_of_line"/>
    <setting id="org.eclipse.jdt.core.formatter.comment.indent_root_tags" value="true"/>
    <setting id="org.eclipse.jdt.core.formatter.insert_space_before_comma_in_enum_declarations" value="do not insert"/>
    <setting id="org.eclipse.jdt.core.formatter.alignment_for_union_type_in_multicatch" value="16"/>
    <setting id="org.eclipse.jdt.core.formatter.insert_space_after_comma_in_explicitconstructorcall_arguments" value="insert"/>
    <setting id="org.eclipse.jdt.core.formatter.insert_space_before_opening_brace_in_switch" value="insert"/>
    <setting id="org.eclipse.jdt.core.formatter.insert_space_before_comma_in_method_declaration_parameters" value="do not insert"/>
    <setting id="org.eclipse.jdt.core.formatter.insert_space_after_comma_in_superinterfaces" value="insert"/>
    <setting id="org.eclipse.jdt.core.formatter.insert_space_before_comma_in_allocation_expression" value="do not insert"/>
    <setting id="org.eclipse.jdt.core.formatter.tabulation.size" value="4"/>
