java上传文件到远程服务器(二)---HttpClient方式(2)
路由中upload方法接受form提交的file文件,并且上传到服务器:
IndexController.java代码如下:
package com.test.web.controller;
import java.io.File;
import java.io.FileOutputStream;
import java.io.IOException;
import java.io.InputStream;
import java.io.OutputStream;
import java.util.HashMap;
import java.util.Iterator;
import java.util.List;
import java.util.Map;
import javax.servlet.http.HttpServletRequest;
import org.apache.commons.fileupload.FileItem;
import org.apache.commons.fileupload.disk.DiskFileItemFactory;
import org.apache.commons.fileupload.servlet.ServletFileUpload;
import org.apache.http.HttpEntity;
import org.apache.http.HttpResponse;
import org.apache.http.HttpStatus;
import org.apache.http.ParseException;
import org.apache.http.client.HttpClient;
import org.apache.http.client.methods.HttpPost;
import org.apache.http.entity.mime.MultipartEntity;
import org.apache.http.entity.mime.content.FileBody;
import org.apache.http.impl.client.DefaultHttpClient;
import org.apache.http.util.EntityUtils;
import org.springframework.stereotype.Controller;
import org.springframework.ui.Model;
import org.springframework.web.bind.annotation.RequestMapping;
* IndexController
@Controller
public class IndexController {
private static final String FAR_SERVICE_DIR = "http://192.168.30.39:8080/receive";// 远程服务器接受文件的路由
private static final long yourMaxRequestSize = 10000000;
@RequestMapping("/")
public String index(Model model) throws IOException {
return "/index";
@RequestMapping("/upload")
public String upload(HttpServletRequest request) throws Exception {
// 判断enctype属性是否为multipart/form-data
boolean isMultipart = ServletFileUpload.isMultipartContent(request);
if (!isMultipart)
throw new IllegalArgumentException(
"上传内容不是有效的multipart/form-data类型.");
// Create a factory for disk-based file items
DiskFileItemFactory factory = new DiskFileItemFactory();
// Create a new file upload handler
ServletFileUpload upload = new ServletFileUpload(factory);
// 设置上传内容的大小限制(单位:字节)
upload.setSizeMax(yourMaxRequestSize);
// Parse the request
List<?> items = upload.parseRequest(request);
Iterator iter = items.iterator();
while (iter.hasNext()) {
FileItem item = (FileItem) iter.next();
if (item.isFormField()) {
// 如果是普通表单字段
String name = item.getFieldName();
String value = item.getString();
} else {
// 如果是文件字段
String fieldName = item.getFieldName();
String fileName = item.getName();
String contentType = item.getContentType();
boolean isInMemory = item.isInMemory();
long sizeInBytes = item.getSize();
// 上传到远程服务器
HashMap<String, FileItem> files = new HashMap<String, FileItem>();
files.put(fileName, item);
uploadToFarServiceByHttpClient(files);
return "redirect:/";
private void uploadToFarServiceByHttpClient(HashMap<String, FileItem> files) {
HttpClient httpclient = new DefaultHttpClient();
try {
HttpPost httppost = new HttpPost(FAR_SERVICE_DIR);
MultipartEntity reqEntity = new MultipartEntity();
Iterator iter = files.entrySet().iterator();
Map.Entry entry = (Map.Entry) iter.next();
String key = (String) entry.getKey();
FileItem val = (FileItem) entry.getValue();
FileBody filebdody = new FileBody(inputstreamtofile(
val.getInputStream(), key));
reqEntity.addPart(key, filebdody);
httppost.setEntity(reqEntity);
HttpResponse response = httpclient.execute(httppost);
int statusCode = response.getStatusLine().getStatusCode();
if (statusCode == HttpStatus.SC_OK) {
System.out.println("服务器正常响应.....");
HttpEntity resEntity = response.getEntity();
System.out.println(EntityUtils.toString(resEntity,"UTF-8"));// httpclient自带的工具类读取返回数据
EntityUtils.consume(resEntity);
} catch (ParseException e) {
// TODO Auto-generated catch block
e.printStackTrace();
} catch (IOException e) {
} finally {
try {
httpclient.getConnectionManager().shutdown();
} catch (Exception ignore) {
public File inputstreamtofile(InputStream ins, String filename)
File file = new File(filename);
OutputStream os = new FileOutputStream(file);
int bytesRead = 0;
byte[] buffer = new byte[8192];
while ((bytesRead = ins.read(buffer, 0, 8192)) != -1) {
os.write(buffer, 0, bytesRead);
os.close();
ins.close();
return file;
