java上传文件到远程服务器(二)---HttpClient方式(3)
服务端
我们仍然在基础项目上fileController中实现接收文件。代码如下:
FileController.java
    package com.test.web.controller;
    import java.io.File;
    import java.util.Iterator;
    import java.util.List;
    import javax.servlet.http.HttpServletRequest;
    import javax.servlet.http.HttpServletResponse;
    import org.apache.commons.fileupload.FileItem;
    import org.apache.commons.fileupload.disk.DiskFileItemFactory;
    import org.apache.commons.fileupload.servlet.ServletFileUpload;
    import org.springframework.stereotype.Controller;
    import org.springframework.web.bind.annotation.RequestMapping;
     * IndexController
    @Controller
    public class FileController {
        //private static final String STORE_FILE_DIR="/usr/local/image/";//文件保存的路径
        private static final String STORE_FILE_DIR="D:\\";//文件保存的路径
        @RequestMapping("/receive")
        public String receive(HttpServletRequest request,HttpServletResponse response) throws Exception {
            // 判断enctype属性是否为multipart/form-data
            boolean isMultipart = ServletFileUpload.isMultipartContent(request);
            if (!isMultipart)
                throw new IllegalArgumentException(
                        "上传内容不是有效的multipart/form-data类型.");
            // Create a factory for disk-based file items
            DiskFileItemFactory factory = new DiskFileItemFactory();
            // Create a new file upload handler
            ServletFileUpload upload = new ServletFileUpload(factory);
            // Parse the request
            List<?> items = upload.parseRequest(request);
            Iterator iter = items.iterator();
            while (iter.hasNext()) {
                FileItem item = (FileItem) iter.next();
                if (item.isFormField()) {
                    // 如果是普通表单字段
                    String name = item.getFieldName();
                    String value = item.getString();
                } else {
                    // 如果是文件字段
                    String fieldName = item.getFieldName();
                    String fileName = item.getName();
                    String contentType = item.getContentType();
                    boolean isInMemory = item.isInMemory();
                    long sizeInBytes = item.getSize();
                    String filePath=STORE_FILE_DIR+fileName;
                    //写入文件到当前服务器磁盘
                    File uploadedFile = new File(filePath);
                    // File uploadedFile = new File("D:\haha.txt");
                    item.write(uploadedFile);
            response.setCharacterEncoding("UTF-8");
             response.getWriter().println("上传成功");
            return null;
我们需要把服务端发布到 远程服务器上 使用tomcat等运行起来。
如果项目中有shiro拦截的话记得设置成  /receive = anon 。让接收文件的路由不被拦截。
然后运行客户端,选择文件就可以上传了。对安全有要求的,可以在客户端加一个key,服务器端接收到请求后验证key,没问题的话 再写入目录和文件。
