目标检测web端网页代码(1)
目标检测web端网页代码(1)
html
    <!doctype html>
    <html lang="zh">
    <head>
        <meta charset="UTF-8">
        <meta http-equiv="X-UA-Compatible" content="IE=edge,chrome=1">
        <meta name="viewport" content="width=device-width, initial-scale=1.0">
        <title>目标检测</title>
        <link href="https://maxcdn.bootstrapcdn.com/bootstrap/3.3.4/css/bootstrap.min.css"
        3
        4
        5
        6
        7
        8
    rel=“stylesheet”>
    <link href="css/fileinput.css" media="all" rel="stylesheet" type="text/css" />
</head>
<body>
    <img src="img/header.jpg" width="100%" height="200"  />
    <div class="container">
    3
    4
    5
            <div class="dataItem">
                    <div class="dataFrame"></div>
            </div>
            <form enctype="multipart/form-data">
                <div class="form-group">
                    <input id="file-select" type="file" >
                </div>
            </form>
                <button type="submit" class="btn btn-primary">Submit</button>
            </form>
        </div>
        <script src="http://apps.bdimg.com/libs/jquery/2.1.1/jquery.min.js"></script>
        <script src="js/fileinput.js" type="text/javascript"></script>
        <script src="js/fileinput_locale_zh.js" type="text/javascript"></script>
        <script>
            $("#file-select").fileinput({
                uploadUrl: '#', // you must set a valid URL here else you will get an error
                allowedFileExtensions : ['jpg', 'png','gif'],
                overwriteInitial: false,
                maxFileSize: 1000,
                maxFilesNum: 10,
                //allowedFileTypes: ['image', 'video', 'flash'],
                slugCallback: function(filename) {
                    return filename.replace('(', '_').replace(']', '_');
            </script>
    </body>
    </html>
