kubernetes-client的使用--java中提交argo工作流(4)
测试通过的完整示例代码
提交普通yaml
ArgoController.java
package com.biologic.api;
import java.io.BufferedReader;
import java.io.ByteArrayInputStream;
import java.io.IOException;
import java.io.InputStream;
import java.io.InputStreamReader;
import java.util.List;
import org.springframework.beans.factory.annotation.Autowired;
import org.springframework.beans.factory.annotation.Value;
import org.springframework.core.io.ClassPathResource;
import org.springframework.stereotype.Controller;
import org.springframework.web.bind.annotation.PathVariable;
import org.springframework.web.bind.annotation.PostMapping;
import org.springframework.web.bind.annotation.RequestMapping;
import org.springframework.web.bind.annotation.RequestParam;
import org.springframework.web.bind.annotation.ResponseBody;
import com.biologic.api.service.LogService;
import io.fabric8.kubernetes.api.model.DoneablePod;
import io.fabric8.kubernetes.api.model.HasMetadata;
import io.fabric8.kubernetes.api.model.Pod;
import io.fabric8.kubernetes.api.model.PodList;
import io.fabric8.kubernetes.client.Config;
import io.fabric8.kubernetes.client.ConfigBuilder;
import io.fabric8.kubernetes.client.DefaultKubernetesClient;
import io.fabric8.kubernetes.client.KubernetesClient;
import io.fabric8.kubernetes.client.dsl.NonNamespaceOperation;
import io.fabric8.kubernetes.client.dsl.PodResource;
@Controller
@RequestMapping(path = "/report/generation/argo")
public class ArgoController {
    public final static String SECRET_TOKEN_ARGO = "123";
    @Value("${env}")
    private String env;
    @Value("${kubernetes.master}")
    private String masterurl;
    @Autowired
    private LogService logService;
    @PostMapping(value = "/{chip}/quality-check")
    @ResponseBody
    public Object quality_check(@RequestParam(value = "token", required = true) String token,
            @PathVariable("chip") String chip) {
        if (!token.equals(SECRET_TOKEN_ARGO)) {
            return "unauthorized";
        logService.printK8sNow("当前环境 " + env);
        String namespace = "default";
        if ("sit".equals(env)) {
          namespace = "sit";
            try {
                ClassPathResource yamlresource = new ClassPathResource("hello.yaml");
                InputStream input=yamlresource.getInputStream();
                StringBuffer sb = new StringBuffer();
                readToBuffer(sb, input);
                String fileContent = sb.toString();
                String fileContent2 = fileContent.replaceFirst("value: hello", "value: " + chip);
                System.out.println(fileContent2);
                InputStream stream = new ByteArrayInputStream(fileContent2.getBytes());
                Config config = new ConfigBuilder().withMasterUrl(masterurl).build();
                KubernetesClient client = new DefaultKubernetesClient(config);
                namespace = client.getNamespace();
                 List<HasMetadata> resources = client.load(stream).get();
                  if (resources.isEmpty()) {
                    System.err.println("No resources loaded from file: " +yamlresource.getPath());
                    return "No resources loaded from file: " +yamlresource.getPath();
                  HasMetadata resource = resources.get(0);
                  if (resource instanceof Pod){
                    Pod pod = (Pod) resource;
                    System.out.println("Creating pod in namespace " + pod.getMetadata().getNamespace());
                    NonNamespaceOperation<Pod, PodList, DoneablePod, PodResource<Pod, DoneablePod>> pods = client.pods().inNamespace(namespace);
                    Pod result = pods.create(pod);
                    System.out.println("Created pod " + result.getMetadata().getName());
                  } else {
                    System.err.println("Loaded resource is not a Pod! " + resource);
                return fileContent2;
            } catch (IOException e) {
                e.printStackTrace();
                System.out.println("argo未找到配置文件");
        return "ok";
     * 将文本文件中的内容读入到buffer中
     * @param buffer
     *            buffer
     * @param filePath
     *            文件路径
     * @throws IOException
     *             异常
     * @author cn.outofmemory
     * @date 2013-1-7
    private void readToBuffer(StringBuffer buffer, InputStream input) throws IOException {
        String line; // 用来保存每行读取的内容
        BufferedReader reader = new BufferedReader(new InputStreamReader(input));
        line = reader.readLine(); // 读取第一行
        while (line != null) { // 如果 line 为空说明读完了
            buffer.append(line); // 将读到的内容添加到 buffer 中
            buffer.append("\n"); // 添加换行符
            line = reader.readLine(); // 读取下一行
        reader.close();
        input.close();
