kubernetes-client的使用--java中提交argo工作流(6)
初始化几个类
ArgoCluster.java
package com.biologic.entity;
import java.util.ArrayList;
import java.util.Map;
import io.fabric8.kubernetes.client.CustomResource;
public class ArgoCluster extends CustomResource{
    private ArgoSpec spec;
    private Map<String,Object> status;
      @Override
      public String toString() {
        return "Argo{" +
            "apiVersion='" + getApiVersion() + '\'' +
            ", metadata=" + getMetadata() +
            ", spec=" + spec +
      public ArgoSpec getSpec() {
        return spec;
      public void setSpec(ArgoSpec spec) {
        this.spec = spec;
    public Map<String, Object> getStatus() {
        return status;
    public void setStatus(Map<String, Object> status) {
        this.status = status;
ArgoSpec.java
import com.fasterxml.jackson.databind.JsonDeserializer;
import com.fasterxml.jackson.databind.annotation.JsonDeserialize;
import io.fabric8.kubernetes.api.model.KubernetesResource;
@JsonDeserialize(
        using = JsonDeserializer.None.class
public class ArgoSpec implements KubernetesResource {
    private Object entrypoint;
      private Object arguments;
      private Object templates;
      private Object volumes;
    public Object getEntrypoint() {
        return entrypoint;
    public void setEntrypoint(Object entrypoint) {
        this.entrypoint = entrypoint;
    public Object getArguments() {
        return arguments;
    public void setArguments(Object arguments) {
        this.arguments = arguments;
    public Object getTemplates() {
        return templates;
    public void setTemplates(Object templates) {
        this.templates = templates;
    public Object getVolumes() {
        return volumes;
    public void setVolumes(Object volumes) {
        this.volumes = volumes;
