kubernetes-client的使用--java中提交argo工作流(8)
完整代码
package com.biologic.api;
import java.io.BufferedReader;
import java.io.ByteArrayInputStream;
import java.io.IOException;
import java.io.InputStream;
import java.io.InputStreamReader;
import java.util.List;
import org.springframework.beans.factory.annotation.Autowired;
import org.springframework.beans.factory.annotation.Value;
import org.springframework.core.io.ClassPathResource;
import org.springframework.stereotype.Controller;
import org.springframework.web.bind.annotation.PathVariable;
import org.springframework.web.bind.annotation.PostMapping;
import org.springframework.web.bind.annotation.RequestMapping;
import org.springframework.web.bind.annotation.RequestParam;
import org.springframework.web.bind.annotation.ResponseBody;
import com.biologic.api.service.LogService;
import com.biologic.entity.ArgoCluster;
import com.biologic.entity.ArgoList;
import com.biologic.entity.DoneableArgo;
import io.fabric8.kubernetes.api.model.DoneablePod;
import io.fabric8.kubernetes.api.model.HasMetadata;
import io.fabric8.kubernetes.api.model.Pod;
import io.fabric8.kubernetes.api.model.PodList;
import io.fabric8.kubernetes.api.model.apiextensions.CustomResourceDefinition;
import io.fabric8.kubernetes.api.model.apiextensions.CustomResourceDefinitionList;
import io.fabric8.kubernetes.client.AppsAPIGroupClient;
import io.fabric8.kubernetes.client.AutoAdaptableKubernetesClient;
import io.fabric8.kubernetes.client.AutoscalingAPIGroupClient;
import io.fabric8.kubernetes.client.BatchAPIGroupClient;
import io.fabric8.kubernetes.client.Config;
import io.fabric8.kubernetes.client.ConfigBuilder;
import io.fabric8.kubernetes.client.CustomResourceList;
import io.fabric8.kubernetes.client.DefaultKubernetesClient;
import io.fabric8.kubernetes.client.ExtensionsAPIGroupClient;
import io.fabric8.kubernetes.client.KubernetesClient;
import io.fabric8.kubernetes.client.KubernetesClientException;
import io.fabric8.kubernetes.client.dsl.MixedOperation;
import io.fabric8.kubernetes.client.dsl.NonNamespaceOperation;
import io.fabric8.kubernetes.client.dsl.PodResource;
import io.fabric8.kubernetes.client.dsl.Resource;
@Controller
@RequestMapping(path = "/report/generation/argo")
public class ArgoController {
    public final static String SECRET_TOKEN_ARGO = "uiuda";
    private static final String ARGO_CRD_NAME = "workflows.argoproj.io";
    @Value("${env}")
    private String env;
    @Value("${kubernetes.master}")
    private String masterurl;
    @Autowired
    private LogService logService;
    @PostMapping(value = "/{chip}/quality-check")
    @ResponseBody
    public Object quality_check(@RequestParam(value = "token", required = true) String token,
            @PathVariable("chip") String chip) {
        if (!token.equals(SECRET_TOKEN_ARGO)) {
            return "unauthorized";
        logService.printK8sNow("当前环境 " + env);
        String namespace = "default";
        if ("sit".equals(env)) {
          namespace = "sit";
            try {
                ClassPathResource yamlresource = new ClassPathResource("hello.yaml");
                InputStream input=yamlresource.getInputStream();
                StringBuffer sb = new StringBuffer();
                readToBuffer(sb, input);
                String fileContent = sb.toString();
                String fileContent2 = fileContent.replaceFirst("value: hello", "value: '" + chip +"'");
                String fileContent3 = fileContent2.replaceFirst("-random", "-" + chip);
                String fileContent4 = fileContent3.replaceFirst("namespace: default", "namespace: " + namespace);
                System.out.println(fileContent4);
                InputStream stream = new ByteArrayInputStream(fileContent4.getBytes());
                Config config = new ConfigBuilder().withMasterUrl(masterurl).build();
                KubernetesClient client = new DefaultKubernetesClient(config);
                CustomResourceDefinition argoCRD = null;
                 try {
                      if (!client.supportsApiPath("/apis/apiextensions.k8s.io/v1beta1") && !client.supportsApiPath("/apis/apiextensions.k8s.io/v1")) {
                        System.out.println("WARNING this cluster does not support the API Group apiextensions.k8s.io");
                        return "fail";
                      CustomResourceDefinitionList list = client.customResourceDefinitions().list();
                      if (list == null) {
                        System.out.println("ERROR no list returned!");
                        return "fail";
                      List<CustomResourceDefinition> items = list.getItems();
                      for (CustomResourceDefinition item : items) {
                        System.out.println("CustomResourceDefinition " + item.getMetadata().getName() + " has version: " + item.getApiVersion());
                        if (ARGO_CRD_NAME.equals(item.getMetadata().getName())) {
                            argoCRD = item;
                    } catch (KubernetesClientException e) {
                      System.out.println("Failed: " + e);
                      e.printStackTrace();
                 if (argoCRD != null) {
                        System.out.println("Found CRD: " + argoCRD.getMetadata().getSelfLink());
                      } else {
                          return "fail";
                 MixedOperation<ArgoCluster, ArgoList, DoneableArgo, Resource<ArgoCluster, DoneableArgo>> argoClient = client.customResources(argoCRD, ArgoCluster.class, ArgoList.class, DoneableArgo.class);
                CustomResourceList<ArgoCluster> argoList =argoClient.list();
                  List<ArgoCluster> items = argoList.getItems();
                  System.out.println("  found " + items.size() + " argo");
                  for (ArgoCluster item : items) {
                    System.out.println("    " + item);
                 ArgoCluster createArgo= argoClient.load(stream).get();
                 ArgoCluster finishpod=argoClient.create(createArgo);
                 String podname=finishpod.getMetadata().getName();
                  Pod pod = client.pods().inNamespace(namespace).withName(podname).get();
                  if (pod !=null){
                    System.out.println("Creating pod in namespace " + pod.getMetadata().getNamespace());
                    System.out.println("Created pod " + podname);
                  } else {
                    System.err.println("not found a Pod! " + podname);
                return fileContent2;
            } catch (IOException e) {
                System.out.println("argo未找到配置文件");
        return "ok";
