python--爬虫--获取和解析存储网页内容--以薄荷网为例(16)
抓取网页原内容
import urllib
import urllib.request
import json
from mgap_spider.dao.categoryPageLinkDao import *
from bs4 import *
import string
import time
import re
def fetchraw(link):
    f = urllib.request.Request(link)
    response = urllib.request.urlopen(f)
    the_page = response.read()
    content = the_page.decode("utf8")
    time.sleep(1)
    #print(content)
    return content
    #contentjson = json.loads(content)
    #print(contentjson)
    #print(contentjson['total_pages'])
for i in range(0, 30000, 100):
    links=findNoDealedLimit(i,100)
    for x in links:
        content=fetchraw(x['link'])
        insertCategoryPageRaw(x['link'],content,x['type'],x['source'])
        dealCategoryPagelink(x['link'])
        print("dealed %s %s %s" % (x['source'], x['type'], x['link']))
解析
from mgap_spider.dao.itemLinkDao import *
import json
from bs4 import *
import string
import time
import re
import _thread
def parserawauto(begin,size):
    linkhead = "http://food.boohee.com/fb/v1/foods/"
    linkend = "/mode_show?token=&user_key=&app_version=2.6.2.1&app_device=Android&os_version=7.1.2&phone_model=M6+Note&channel=meizu"
    while 1:
        try:
            count=countNoDealedPageRaw()
            if count==0:
                break
            raws=findNoDealedRawLimit(begin,size)
            for raw in raws:
                if raw['source'] == '食物库app':
                    content=raw['content']
                    foods = contentjson['foods']
                    for food in foods:
                        link=linkhead+food['code']+linkend
                        print("dealed %s %s" % (food['code'], food['name']))
                        insertItemLink(food['code'],food['name'],raw['link'],link,raw['type'],raw['source'])
                        dealCategoryPageRaw(raw['link'])
                    print("dealed %s %s %s" % (raw['source'], raw['type'], raw['link']))
                else:
                    soup = BeautifulSoup(content)
                    div = soup.find("div", class_="widget-food-list")
                    ul = div.find("ul", class_="food-list")
                    boxs = ul.find_all("div", class_="text-box")
                    for box in boxs:
                        node = box.find('a', href=re.compile(r'/shiwu/\w+'))
                        code=node['href'].replace("/shiwu/","")
                        #code=ahref.replace("/shiwu/","")
                        name=node['title']
                        link=linkhead+code+linkend
                        print("dealed %s %s" % (code, name))
                        insertItemLink(code,name,raw['link'],link,raw['type'],raw['source'])
        except Exception as e:
            print(e)
    return "begin "+str(begin)+" finish"+datetime.now()
def run():
    # 创建两个线程
    try:
        _thread.start_new_thread(parserawauto, (0, 100))
        _thread.start_new_thread(parserawauto, (100, 100))
       print(e)
       print("Error: unable to start thread")
run()
while 1:
    pass
