python项目中通过环境变量的方式使用secret密钥参数(1)
创建私密参数secret
方式一 直接设置密钥参数
kubectl create secret generic my-secret --from-literal=mongohost=192.168.30.11 --from-literal=mongoport=27017
方式二 通过yaml创建
需要注意的是通过yaml创建时参数的值需要为base64编码
使用转换方法如下:
$ echo -n "192.168.30.11" | base64
MTkyLjE2OC4zMC4xMQ==
$ echo -n "27017" | base64
MjcwMTc=
$ echo -n "mypassword" | base64
Mjdsdaffdd=
$ echo -n "5600" | base64
NTYwMA==
则创建的secret.yml文件内容如下:
apiVersion: v1
kind: Secret
metadata:
data:
  mongohost: MTkyLjE2OC4zMC4xMQ==
  mongoport: MjcwMTc=
  mongousername: Mjdsdaffdd=
  mongopassword: Mjdsdaffdd=
  mysqlhost: MTkyLjE2OC4zMC4xMQ==
  mysqlport: NTYwMA==
  mysqlusername: Mjdsdaffdd=
  mysqlpassword: Mjdsdaffdd=
使用yml文件创建命令如下:
kubectl create -f  secret.yml
查看密钥
kubectl get secret  my-secret -o yaml
解码密码字段:
$ echo "MTkyLjE2OC4zMC4xMQ==" | base64 --decode
192.168.30.11
argo yml中引用secret的密钥
注意my-secret是secret的名称,以及字段的对应
关键配置如下:
        env:
          - name: MONGO_HOST
            valueFrom:
              secretKeyRef:
                name: my-secret    # name of an existing k8s secret
                key: mongohost
          - name: MONGO_PORT
            valueFrom:
              secretKeyRef:
                key: mongoport
完整yml内容参考
apiVersion: argoproj.io/v1alpha1
kind: Workflow
metadata:
  generateName: mgap-module-name-
spec:
  entrypoint: diamond
#  activeDeadlineSeconds: 300
  arguments:
    parameters:
    - name: chip-id
      value: chip_id
    - name: chip-version
      value: v2_1  # v1.0 v2.0 v2.1
    - name: env
      value: beta  # test beta prod
  templates:
    - name: diamond
      dag:
        tasks:
          - name: module-step
            template: module
            arguments:
              parameters:
                - name: chip-id
                  value: "{{workflow.parameters.chip-id}}"
                  value: "{{workflow.parameters.chip-version}}"
                - name: env
                  value: "{{workflow.parameters.env}}"
    - name: module
      retryStrategy:
        limit: 20
      inputs:
        parameters:
          - name: chip-id
          - name: env
      container:
        image: mydocker/module/module:beta
        command: [sh, -c]
        args: ["date;cd /root;ls;start;sleep 10m;date"]
        env:
          - name: MONGO_HOST
            valueFrom:
              secretKeyRef:
                key: mongohost
          - name: MONGO_PORT
            valueFrom:
              secretKeyRef:
                key: mongoport
          - name: MONGO_USERNAME
            valueFrom:
              secretKeyRef:
                name:my-secret     # name of an existing k8s secret
                key: mongousername
          - name: MONGO_PASSWORD
            valueFrom:
              secretKeyRef:
                key: mongopassword
          - name: MYSQL_HOST
            valueFrom:
              secretKeyRef:
                key: mysqlhost
          - name: MYSQL_PORT
            valueFrom:
              secretKeyRef:
                key: mysqlport
          - name: MYSQL_USERNAME
            valueFrom:
              secretKeyRef:
                key: mysqlusername
          - name: MYSQL_PASSWORD
            valueFrom:
              secretKeyRef:
                key: mysqlpassword
