遇到问题--mongodb--Prematurely reached end of stream
遇到问题
spring boot执行比较频繁的大数据量mongodb查询时报错
2018-10-18 02:21:10.414 ERROR 1 --- [nio-9999-exec-1] c.m.s.support.web.MFErrorController : 服务器出现异常
org.springframework.data.mongodb.UncategorizedMongoDbException: Prematurely reached end of stream; nested exception is com.mongodb.MongoSocketReadException: Prematurely reached end of stream
at org.springframework.data.mongodb.core.MongoExceptionTranslator.translateExceptionIfPossible(MongoExceptionTranslator.java:107)
at org.springframework.data.mongodb.core.MongoTemplate.potentiallyConvertRuntimeException(MongoTemplate.java:2135)
at org.springframework.data.mongodb.core.MongoTemplate.executeFindOneInternal(MongoTemplate.java:1925)
at org.springframework.data.mongodb.core.MongoTemplate.doFindOne(MongoTemplate.java:1733)
at org.springframework.data.mongodb.core.MongoTemplate.findOne(MongoTemplate.java:603)
at org.springframework.data.mongodb.core.MongoTemplate.findOne(MongoTemplate.java:598)
at com.biologic.api.service.impl.ProjectNewlyServiceImpl.findResultSummary(ProjectNewlyServiceImpl.java:495)
at com.biologic.api.ProjectNewlyController.findResultCount(ProjectNewlyController.java:53)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke(Method.java:498)
at org.springframework.web.method.support.InvocableHandlerMethod.doInvoke(InvocableHandlerMethod.java:205)
at org.springframework.web.method.support.InvocableHandlerMethod.invokeForRequest(InvocableHandlerMethod.java:133)
at org.springframework.web.servlet.mvc.method.annotation.ServletInvocableHandlerMethod.invokeAndHandle(ServletInvocableHandlerMethod.java:116)
at org.springframework.web.servlet.mvc.method.annotation.RequestMappingHandlerAdapter.invokeHandlerMethod(RequestMappingHandlerAdapter.java:827)
at org.springframework.web.servlet.mvc.method.annotation.RequestMappingHandlerAdapter.handleInternal(RequestMappingHandlerAdapter.java:738)
at org.springframework.web.servlet.mvc.method.AbstractHandlerMethodAdapter.handle(AbstractHandlerMethodAdapter.java:85)
at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:963)
at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:897)
at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:970)
at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:861)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:622)
at org.springframework.web.servlet.FrameworkServlet.service(FrameworkServlet.java:846)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:729)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:230)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:165)
at org.apache.tomcat.websocket.server.WsFilter.doFilter(WsFilter.java:52)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:192)
at org.springframework.web.filter.RequestContextFilter.doFilterInternal(RequestContextFilter.java:99)
at org.springframework.web.filter.OncePerRequestFilter.doFilter(OncePerRequestFilter.java:107)
at org.springframework.web.filter.HttpPutFormContentFilter.doFilterInternal(HttpPutFormContentFilter.java:105)
at org.springframework.web.filter.HiddenHttpMethodFilter.doFilterInternal(HiddenHttpMethodFilter.java:81)
at org.springframework.web.filter.CharacterEncodingFilter.doFilterInternal(CharacterEncodingFilter.java:197)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:198)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:96)
at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:474)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:140)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:79)
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:87)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:349)
at org.apache.coyote.http11.Http11Processor.service(Http11Processor.java:783)
at org.apache.coyote.AbstractProcessorLight.process(AbstractProcessorLight.java:66)
at org.apache.coyote.AbstractProtocol$ConnectionHandler.process(AbstractProtocol.java:798)
at org.apache.tomcat.util.net.NioEndpoint$SocketProcessor.doRun(NioEndpoint.java:1434)
at org.apache.tomcat.util.net.SocketProcessorBase.run(SocketProcessorBase.java:49)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617)
at org.apache.tomcat.util.threads.TaskThread$WrappingRunnable.run(TaskThread.java:61)
at java.lang.Thread.run(Thread.java:745)
Caused by: com.mongodb.MongoSocketReadException: Prematurely reached end of stream
at com.mongodb.connection.SocketStream.read(SocketStream.java:88)
at com.mongodb.connection.InternalStreamConnection.receiveResponseBuffers(InternalStreamConnection.java:494)
at com.mongodb.connection.InternalStreamConnection.receiveMessage(InternalStreamConnection.java:224)
at com.mongodb.connection.UsageTrackingInternalConnection.receiveMessage(UsageTrackingInternalConnection.java:96)
at com.mongodb.connection.DefaultConnectionPool$PooledConnection.receiveMessage(DefaultConnectionPool.java:440)
at com.mongodb.connection.CommandProtocol.execute(CommandProtocol.java:112)
at com.mongodb.connection.DefaultServer$DefaultServerProtocolExecutor.execute(DefaultServer.java:168)
at com.mongodb.connection.DefaultServerConnection.executeProtocol(DefaultServerConnection.java:289)
at com.mongodb.connection.DefaultServerConnection.command(DefaultServerConnection.java:176)
at com.mongodb.operation.CommandOperationHelper.executeWrappedCommandProtocol(CommandOperationHelper.java:216)
at com.mongodb.operation.CommandOperationHelper.executeWrappedCommandProtocol(CommandOperationHelper.java:207)
at com.mongodb.operation.CommandOperationHelper.executeWrappedCommandProtocol(CommandOperationHelper.java:113)
at com.mongodb.operation.FindOperation$1.call(FindOperation.java:516)
at com.mongodb.operation.FindOperation$1.call(FindOperation.java:510)
at com.mongodb.operation.OperationHelper.withConnectionSource(OperationHelper.java:431)
at com.mongodb.operation.OperationHelper.withConnection(OperationHelper.java:404)
at com.mongodb.operation.FindOperation.execute(FindOperation.java:510)
at com.mongodb.operation.FindOperation.execute(FindOperation.java:81)
at com.mongodb.Mongo.execute(Mongo.java:836)
at com.mongodb.Mongo$2.execute(Mongo.java:823)
at com.mongodb.DBCursor.initializeCursor(DBCursor.java:870)
at com.mongodb.DBCursor.hasNext(DBCursor.java:142)
at com.mongodb.DBCursor.one(DBCursor.java:679)
at com.mongodb.DBCollection.findOne(DBCollection.java:833)
at com.mongodb.DBCollection.findOne(DBCollection.java:796)
at com.mongodb.DBCollection.findOne(DBCollection.java:743)
at org.springframework.data.mongodb.core.MongoTemplate$FindOneCallback.doInCollection(MongoTemplate.java:2186)
at org.springframework.data.mongodb.core.MongoTemplate$FindOneCallback.doInCollection(MongoTemplate.java:2170)
at org.springframework.data.mongodb.core.MongoTemplate.executeFindOneInternal(MongoTemplate.java:1922)
... 59 common frames omitted |
