Spring Boot中使用mysql数据库(1)
引入maven包
在pom.xml中
<dependencies></dependencies>
新增引入如下:
<!-- JPA Data (We are going to use Repositories, Entities, Hibernate, etc...) -->
        <dependency>
            <groupId>org.springframework.boot</groupId>
            <artifactId>spring-boot-starter-data-jpa</artifactId>
        </dependency>
        <!-- Use MySQL Connector-J -->
        <dependency>
            <groupId>mysql</groupId>
            <artifactId>mysql-connector-java</artifactId>
        </dependency>
完整的pom.xml如下:
<project xmlns="http://maven.apache.org/POM/4.0.0" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:schemaLocation="http://maven.apache.org/POM/4.0.0 http://maven.apache.org/xsd/maven-4.0.0.xsd">
  <modelVersion>4.0.0</modelVersion>
  <groupId>com.biologic</groupId>
  <artifactId>biologic</artifactId>
  <version>0.0.1-SNAPSHOT</version>
   <!-- 编译版本为JDK 1.8 -->
    <properties>
        <project.build.sourceEncoding>UTF-8</project.build.sourceEncoding>
        <project.reporting.outputEncoding>UTF-8</project.reporting.outputEncoding>
        <java.version>1.8</java.version>
         <ms.version>1.0-SNAPSHOT</ms.version>
    </properties>
    <!-- Spring Boot 核心jar包 -->
    <parent>
        <artifactId>spring-boot-starter-parent</artifactId>
        <version>1.5.3.RELEASE</version>
    </parent>
    <dependencies>
        <dependency>
        </dependency>
        <dependency>
        </dependency>
        <dependency>
            <artifactId>spring-boot-starter-web</artifactId>
        </dependency>
        <dependency>
        <artifactId>spring-boot-starter-data-mongodb</artifactId>
    </dependency>
    <dependency>
            <groupId>com.mofang</groupId>
            <artifactId>23mofang-domain</artifactId>
            <version>2.15.1-RELEASE</version>
        </dependency>
    </dependencies>
    <build>
  <plugins>
    <plugin>
        <artifactId>spring-boot-maven-plugin</artifactId>
    </plugin>
  </plugins>
</build>
</project>
