Spring Boot使用JPA多条件查询mysql(2)
新建实体相关的接口继承JpaSpecificationExecutor
QualityCheckRepository.java
代码如下:
package com.biologic.api.service;
import org.springframework.data.jpa.repository.JpaRepository;
import org.springframework.data.jpa.repository.JpaSpecificationExecutor;
import org.springframework.stereotype.Service;
import com.biologic.entity.QualityCheck;
@Service
public interface QualityCheckRepository extends JpaRepository<QualityCheck, Long>, JpaSpecificationExecutor<QualityCheck> {
使用方法
重写findAll中的new Specification()方法和public Predicate toPredicate(Root root, CriteriaQuery
package com.biologic.api;
import java.util.ArrayList;
import java.util.Arrays;
import java.util.Date;
import java.util.HashMap;
import java.util.List;
import java.util.UUID;
import javax.persistence.criteria.CriteriaBuilder;
import javax.persistence.criteria.CriteriaQuery;
import javax.persistence.criteria.Predicate;
import javax.persistence.criteria.Root;
import org.apache.commons.collections.CollectionUtils;
import org.springframework.beans.factory.annotation.Autowired;
import org.springframework.beans.factory.annotation.Qualifier;
import org.springframework.data.jpa.domain.Specification;
import org.springframework.data.mongodb.core.MongoTemplate;
import org.springframework.data.mongodb.core.query.Criteria;
import org.springframework.data.mongodb.core.query.Query;
import org.springframework.stereotype.Controller;
import org.springframework.web.bind.annotation.GetMapping;
import org.springframework.web.bind.annotation.RequestMapping;
import org.springframework.web.bind.annotation.ResponseBody;
import com.biologic.api.service.QualityCheckRepository;
@Controller
@RequestMapping(path = "/demo")
public class QualityCheckController {
    @Autowired
    private QualityCheckRepository qualityCheckRepository;
    @GetMapping(path = "/qualityCheck")
    public @ResponseBody String qualityCheck() {
        QualityCheck model = new QualityCheck();
        model.setQualified(1);
        model.setProcessed(0);
        List<QualityCheck> results = findSearch(model);
        for (QualityCheck qualityCheck : results) {
            System.out.println("正在质检:" + qualityCheck.getId());
                qualityCheck.setProcessed(1);
            qualityCheckRepository.save(qualityCheck);
        return "ok";
    public List<QualityCheck> findSearch(QualityCheck model) {
        List<QualityCheck> result = qualityCheckRepository.findAll(new Specification<QualityCheck>() {
            @Override
            public Predicate toPredicate(Root<QualityCheck> root, CriteriaQuery<?> query, CriteriaBuilder cb) {
                List<Predicate> list = new ArrayList<Predicate>();
                list.add(cb.equal(root.get("qualified").as(Integer.class), model.getQualified()));
                list.add(cb.equal(root.get("processed").as(Integer.class), model.getProcessed()));
                if (model.getVersion() != null && !model.getVersion().equals("")) {
                    list.add(cb.equal(root.get("version").as(String.class), model.getVersion()));
                    list.add(cb.like(root.get("version").as(String.class), "%" + model.getVersion() + "%"));
                // 日期
                if (model.getUpload_time() != null) {
                    Date startDate = model.getUpload_time();
                    Date endDate = new Date();
                    // 处理字符串时间
                    // SimpleDateFormat format = new SimpleDateFormat("yyyy-MM-dd");
                    // try {
                    // startDate = format.parse(date);
                    // } catch (ParseException e) {
                    // startDate = new Date(946656000000L);//2000 01 01
                    // endDate = startDate;
                    // Calendar calendar = Calendar.getInstance() ;
                    // calendar.setTime(endDate);
                    // calendar.add(Calendar.DATE, 1);
                    // endDate = calendar.getTime();
                    // calendar = null;
                    list.add(cb.between(root.<Date>get("upload_time"), startDate, endDate));
                Predicate[] p = new Predicate[list.size()];
                return cb.and(list.toArray(p));
        return result;
