手动安装ceph和使用(4)
手动安装ceph和使用(4)
创建Monitor(admin节点)
在ceph1、ceph2、ceph3上创建monitor
sudo mkdir myceph
cd myceph
sudo ceph-deploy new ceph1 ceph2 ceph3
正确运行输出如下:
[zzq@localhost myceph]$ sudo ceph-deploy new ceph1 ceph2 ceph3
[ceph_deploy.conf][DEBUG ] found configuration file at: /root/.cephdeploy.conf
[ceph_deploy.cli][INFO  ] Invoked (1.5.37): /usr/bin/ceph-deploy new ceph1 ceph2 ceph3
[ceph_deploy.cli][INFO  ] ceph-deploy options:
[ceph_deploy.cli][INFO  ]  username                      : None
[ceph_deploy.cli][INFO  ]  func                          : <function new at 0xa66e60>
[ceph_deploy.cli][INFO  ]  verbose                       : False
[ceph_deploy.cli][INFO  ]  overwrite_conf                : False
[ceph_deploy.cli][INFO  ]  quiet                         : False
[ceph_deploy.cli][INFO  ]  cd_conf                       : <ceph_deploy.conf.cephdeploy.Conf instance at 0x7fb7f161e638>
[ceph_deploy.cli][INFO  ]  cluster                       : ceph
[ceph_deploy.cli][INFO  ]  ssh_copykey                   : True
[ceph_deploy.cli][INFO  ]  mon                           : ['ceph1', 'ceph2', 'ceph3']
[ceph_deploy.cli][INFO  ]  public_network                : None
[ceph_deploy.cli][INFO  ]  ceph_conf                     : None
[ceph_deploy.cli][INFO  ]  cluster_network               : None
[ceph_deploy.cli][INFO  ]  default_release               : False
[ceph_deploy.cli][INFO  ]  fsid                          : None
[ceph_deploy.new][DEBUG ] Creating new cluster named ceph
[ceph_deploy.new][INFO  ] making sure passwordless SSH succeeds
[ceph1][DEBUG ] connected to host: localhost.mongodb0
[ceph1][INFO  ] Running command: ssh -CT -o BatchMode=yes ceph1
[ceph1][DEBUG ] connected to host: ceph1
[ceph1][DEBUG ] detect platform information from remote host
[ceph1][DEBUG ] detect machine type
[ceph1][DEBUG ] find the location of an executable
[ceph1][INFO  ] Running command: /sbin/ip link show
[ceph1][INFO  ] Running command: /sbin/ip addr show
[ceph1][DEBUG ] IP addresses found: [u'192.168.199.81']
[ceph_deploy.new][DEBUG ] Resolving host ceph1
[ceph_deploy.new][DEBUG ] Monitor ceph1 at 192.168.199.81
[ceph2][DEBUG ] connected to host: localhost.mongodb0
[ceph2][INFO  ] Running command: ssh -CT -o BatchMode=yes ceph2
[ceph2][DEBUG ] connected to host: ceph2
[ceph2][DEBUG ] detect platform information from remote host
[ceph2][DEBUG ] detect machine type
[ceph2][DEBUG ] find the location of an executable
[ceph2][INFO  ] Running command: /sbin/ip link show
[ceph2][INFO  ] Running command: /sbin/ip addr show
[ceph2][DEBUG ] IP addresses found: [u'192.168.199.82']
[ceph_deploy.new][DEBUG ] Resolving host ceph2
[ceph_deploy.new][DEBUG ] Monitor ceph2 at 192.168.199.82
[ceph3][DEBUG ] connected to host: localhost.mongodb0
[ceph3][INFO  ] Running command: ssh -CT -o BatchMode=yes ceph3
[ceph3][DEBUG ] connected to host: ceph3
[ceph3][DEBUG ] detect platform information from remote host
[ceph3][DEBUG ] detect machine type
[ceph3][DEBUG ] find the location of an executable
[ceph3][INFO  ] Running command: /sbin/ip link show
[ceph3][INFO  ] Running command: /sbin/ip addr show
[ceph3][DEBUG ] IP addresses found: [u'192.168.199.83']
[ceph_deploy.new][DEBUG ] Resolving host ceph3
[ceph_deploy.new][DEBUG ] Monitor ceph3 at 192.168.199.83
[ceph_deploy.new][DEBUG ] Monitor initial members are ['ceph1', 'ceph2', 'ceph3']
[ceph_deploy.new][DEBUG ] Monitor addrs are ['192.168.199.81', '192.168.199.82', '192.168.199.83']
[ceph_deploy.new][DEBUG ] Creating a random mon key...
[ceph_deploy.new][DEBUG ] Writing monitor keyring to ceph.mon.keyring...
[ceph_deploy.new][DEBUG ] Writing initial config to ceph.conf...
Error in sys.exitfunc:
[zzq@localhost myceph]$ ls
ceph.conf  ceph-deploy-ceph.log  ceph.mon.keyring
