手动安装ceph和使用(9)
手动安装ceph和使用(9)
创建OSD(admin节点)
ceph磁盘相关命令参考:
http://docs.ceph.org.cn/man/8/ceph-disk/
列举磁盘
sudo ceph-deploy disk list ceph1
sudo ceph-deploy disk list ceph2
sudo ceph-deploy disk list ceph3
输出如下:
[zzq@localhost ~]$ sudo ceph-deploy disk list ceph1
[ceph_deploy.conf][DEBUG ] found configuration file at: /root/.cephdeploy.conf
[ceph_deploy.cli][INFO  ] Invoked (1.5.37): /usr/bin/ceph-deploy disk list ceph1
[ceph_deploy.cli][INFO  ] ceph-deploy options:
[ceph_deploy.cli][INFO  ]  username                      : None
[ceph_deploy.cli][INFO  ]  verbose                       : False
[ceph_deploy.cli][INFO  ]  overwrite_conf                : False
[ceph_deploy.cli][INFO  ]  subcommand                    : list
[ceph_deploy.cli][INFO  ]  quiet                         : False
[ceph_deploy.cli][INFO  ]  cd_conf                       : <ceph_deploy.conf.cephdeploy.Conf instance at 0x1d53fc8>
[ceph_deploy.cli][INFO  ]  cluster                       : ceph
[ceph_deploy.cli][INFO  ]  func                          : <function disk at 0x1d44de8>
[ceph_deploy.cli][INFO  ]  ceph_conf                     : None
[ceph_deploy.cli][INFO  ]  default_release               : False
[ceph_deploy.cli][INFO  ]  disk                          : [('ceph1', None, None)]
[ceph1][DEBUG ] connected to host: ceph1
[ceph1][DEBUG ] detect platform information from remote host
[ceph1][DEBUG ] detect machine type
[ceph1][DEBUG ] find the location of an executable
[ceph_deploy.osd][INFO  ] Distro info: CentOS 6.9 Final
[ceph_deploy.osd][DEBUG ] Listing disks on ceph1...
[ceph1][INFO  ] Running command: /usr/sbin/ceph-disk list
[ceph1][DEBUG ] /dev/sda :
[ceph1][DEBUG ]  /dev/sda1 other, ext4, mounted on /boot
[ceph1][DEBUG ]  /dev/sda2 other, LVM2_member
[ceph1][DEBUG ] /dev/sdb :
[ceph1][DEBUG ]  /dev/sdb1 other, ext4, mounted on /ceph
[ceph1][DEBUG ] /dev/sr0 other, unknown
Error in sys.exitfunc:
擦净磁盘
sudo ceph-deploy disk zap ceph1:/dev/sdb
sudo ceph-deploy disk zap ceph2:/dev/sdb
sudo ceph-deploy disk zap ceph3:/dev/sdb
正确输出如下:
[zzq@localhost ~]$ sudo ceph-deploy disk zap ceph1:/dev/sdb
[ceph_deploy.cli][INFO  ] Invoked (1.5.37): /usr/bin/ceph-deploy disk zap ceph1:/dev/sdb
[ceph_deploy.cli][INFO  ]  subcommand                    : zap
[ceph_deploy.cli][INFO  ]  cd_conf                       : <ceph_deploy.conf.cephdeploy.Conf instance at 0x276efc8>
[ceph_deploy.cli][INFO  ]  func                          : <function disk at 0x275fde8>
[ceph_deploy.cli][INFO  ]  disk                          : [('ceph1', '/dev/sdb', None)]
[ceph_deploy.osd][DEBUG ] zapping /dev/sdb on ceph1
[ceph1][DEBUG ] zeroing last few blocks of device
[ceph1][INFO  ] Running command: /usr/sbin/ceph-disk zap /dev/sdb
[ceph1][DEBUG ]
[ceph1][DEBUG ] ***************************************************************
[ceph1][DEBUG ] Found invalid GPT and valid MBR; converting MBR to GPT format
[ceph1][DEBUG ] in memory.
[ceph1][DEBUG ]
[ceph1][DEBUG ] Warning: The kernel is still using the old partition table.
[ceph1][DEBUG ] The new table will be used at the next reboot.
[ceph1][DEBUG ] GPT data structures destroyed! You may now partition the disk using fdisk or
[ceph1][DEBUG ] other utilities.
[ceph1][DEBUG ] Creating new GPT entries.
[ceph1][DEBUG ] The operation has completed successfully.
[ceph1][WARNIN] error deleting partition 1: BLKPG: Device or resource busy
[ceph1][WARNIN] error deleting partitions 2-256: BLKPG: No such device or address
Unhandled exception in thread started by
[zzq@localhost ~]$
准备OSD
注意prepare的盘最好使用单独的盘,单独使用分区会有点麻烦。而且不能是已经挂载的盘。
在每个节点上先解除挂载
sudo umount /dev/sdb1
在admin节点上运行
sudo ceph-deploy osd prepare ceph1:/dev/sdb
sudo ceph-deploy osd prepare ceph2:/dev/sdb
sudo ceph-deploy osd prepare ceph3:/dev/sdb
正确输出如下:
[zzq@localhost ~]$ sudo ceph-deploy osd prepare ceph1:/dev/sdb
[ceph_deploy.cli][INFO  ] Invoked (1.5.37): /usr/bin/ceph-deploy osd prepare ceph1:/dev/sdb
[ceph_deploy.cli][INFO  ]  dmcrypt                       : False
[ceph_deploy.cli][INFO  ]  bluestore                     : None
[ceph_deploy.cli][INFO  ]  subcommand                    : prepare
[ceph_deploy.cli][INFO  ]  dmcrypt_key_dir               : /etc/ceph/dmcrypt-keys
[ceph_deploy.cli][INFO  ]  cd_conf                       : <ceph_deploy.conf.cephdeploy.Conf instance at 0xe145a8>
[ceph_deploy.cli][INFO  ]  fs_type                       : xfs
[ceph_deploy.cli][INFO  ]  func                          : <function osd at 0xe02d70>
[ceph_deploy.cli][INFO  ]  zap_disk                      : False
[ceph_deploy.osd][DEBUG ] Preparing cluster ceph disks ceph1:/dev/sdb:
[ceph_deploy.osd][DEBUG ] Deploying osd to ceph1
[ceph1][DEBUG ] write cluster configuration to /etc/ceph/{cluster}.conf
[ceph_deploy.osd][DEBUG ] Preparing host ceph1 disk /dev/sdb journal None activate False
[ceph1][INFO  ] Running command: /usr/sbin/ceph-disk -v prepare --cluster ceph --fs-type xfs -- /dev/sdb
[ceph1][WARNIN] INFO:ceph-disk:Running command: /usr/bin/ceph-osd --cluster=ceph --show-config-value=fsid
[ceph1][WARNIN] INFO:ceph-disk:Running command: /usr/bin/ceph-conf --cluster=ceph --name=osd. --lookup osd_mkfs_options_xfs
[ceph1][WARNIN] INFO:ceph-disk:Running command: /usr/bin/ceph-conf --cluster=ceph --name=osd. --lookup osd_fs_mkfs_options_xfs
[ceph1][WARNIN] INFO:ceph-disk:Running command: /usr/bin/ceph-conf --cluster=ceph --name=osd. --lookup osd_mount_options_xfs
[ceph1][WARNIN] INFO:ceph-disk:Running command: /usr/bin/ceph-conf --cluster=ceph --name=osd. --lookup osd_fs_mount_options_xfs
[ceph1][WARNIN] INFO:ceph-disk:Running command: /usr/bin/ceph-osd --cluster=ceph --show-config-value=osd_journal_size
[ceph1][WARNIN] INFO:ceph-disk:Running command: /usr/bin/ceph-conf --cluster=ceph --name=osd. --lookup osd_cryptsetup_parameters
[ceph1][WARNIN] INFO:ceph-disk:Running command: /usr/bin/ceph-conf --cluster=ceph --name=osd. --lookup osd_dmcrypt_key_size
[ceph1][WARNIN] INFO:ceph-disk:Running command: /usr/bin/ceph-conf --cluster=ceph --name=osd. --lookup osd_dmcrypt_type
[ceph1][WARNIN] INFO:ceph-disk:Will colocate journal with data on /dev/sdb
[ceph1][WARNIN] DEBUG:ceph-disk:Creating journal partition num 2 size 5120 on /dev/sdb
[ceph1][WARNIN] INFO:ceph-disk:Running command: /usr/sbin/sgdisk --new=2:0:5120M --change-name=2:ceph journal --partition-guid=2:2f50f047-1d68-4b0f-afb7-0eb8ae9e9d22 --typecode=2:45b0969e-9b03-4f30-b4c6-b4b80ceff106 --mbrtogpt -- /dev/sdb
[ceph1][DEBUG ] Setting name!
[ceph1][DEBUG ] partNum is 1
[ceph1][DEBUG ] REALLY setting name!
